XBMC stuttering playback of video
Discussion in 'Original Xbox' started by richard plumb, Jul 11, 2006.
  1. richard plumb
    richard plumb Active Member
    Jan 27, 2002
    13,155
    +884
    My boss has just modded his xbox and got XBMC on it. But he's having problems getting video to play properly.
    He has access to both SAMBA and XNSP(?) shares and can ftp to the box getting a minimum of 12Mb/s (wireless) but usually more.
    But when viewing divxs, there is sometimes stuttering. Sometimes at the beginning, sometimes not for 20 minutes. These are low bitrate (eg 450MB for an hour).
    So transfer speed doesn't seem to be the issue, but any ideas what might be?
    He's wired the xbox into his wireless router/modem, and his PC has a wireless usb stick in it. Using windows firewall and CCX gui lite (enabled through the firewall). The stuttering happens whether using ccxgui or samba shares.
  2. hambo
    hambo Member
    Aug 16, 2004
    228
    +6
    try reducing the cache settings in XBMC
  3. triplea4uk
    triplea4uk Member
    Jan 12, 2002
    1,946
    48
    +90
    I find it better to have a shared folder on PC then use the workgroup method also he should get the latest version of XBMC I know older versions do tend to be very buggy.
    Last thing clear the cache z x y
  4. sibeer
    sibeer Active Member
    Jul 17, 2005
    2,723
    +129
    Workgroup shares are definatley the way to go :thumbsup:
  5. mickrick
    mickrick New Member
    Jul 1, 2001
    891
    +22
    Does that mean delete everything in those directories?
    Also, I believe the old build (e:\apps\xbmc folder) and the TDATA and UDATA "0face008" files should be deleted everytime a new build is installed. This reduces compatibility issues between builds.
  6. triplea4uk
    triplea4uk Member
    Jan 12, 2002
    1,946
    48
    +90
    Yeah there just the cache so there like temp files as such.
    Your right you should also delete the other files you listed when you install a new version
  7. mickrick
    mickrick New Member
    Jul 1, 2001
    891
    +22
    Agreed 100% (except when your network goes t*ts up).
