Windows 8 Preview available
Discussion in 'PC Gaming Forum' started by wolvers, Feb 29, 2012.
  1. RandomLee
    RandomLee Active Member
    Feb 17, 2006
    6,639
    +1,374
    Downloading to test in Virtual Box but on first glance at the previews it's all a bit Windows Phone for me. Can't really say I've ever been keen on Metro. Still, it's new and I always like to check out new releases so I'll give it a whirl and hopefully will be able to make it look all nice and minimalist :)
  2. Dazimus
    Dazimus Active Member
    Nov 6, 2007
    3,768
    +654
    I really like how well the desktop runs, I like Metro UI as I use a Windows Phone 7 so I'm used to the UI already.
    Unfortunately I'm going to have to go back to Windows 7 as the Xonar app doesn't work in W8 so I can't use the headphones plugged into my front panel of my PC :(
  3. TheNameIsJambo
    TheNameIsJambo Active Member
    Feb 4, 2011
    5,550
    +1,463
  4. Grangey.
    Grangey. Active Member
    Apr 24, 2006
    5,458
    +782
    Doesnt need a download mate
    I cant confirm if this works but it would be good for someone to give it a go!
    There is also
    http://www.thewindowsclub.com/metro-ui-tweaker-windows-8-released
    which looks interesting
  5. TheNameIsJambo
    Feb 4, 2011
    5,550
    +1,463
    Doesn't work. The registry key was removed for the Consumer Preview, tested it last night - It was available in the Developer Preview.
    You can either add a 'Toolbar', by right clicking on the Taskbar and pointing it to the Program Data\Microsoft\Start Menu directory or install StartVi.
  6. wolvers
    wolvers Active Member
    Jun 10, 2008
    6,453
    +1,114
    Anyone know if it's possible to upgrade a Vista install to Win8?
  7. Grangey.
    Apr 24, 2006
    5,458
    +782
    Upgrade? pfft dirty word.
    Clean install ftw.
    + Im sure windows 8 is based on the same stuff as 7, and in 7 could you not only upgrade from XP as it was based on the same stuff not vista?
    • Thanks Thanks x 1
  8. Chuck Norris
    Chuck Norris Well-Known Member
    Jul 13, 2011
    5,653
    +3,891
    Think I read only windows 7 is upgradable and any OS below is a fresh install.
    • Thanks Thanks x 1
  9. wolvers
    Jun 10, 2008
    6,453
    +1,114
  10. Stockholm
    Stockholm Active Member
    Sep 15, 2004
    2,780
    +631
    It seems that a third-party software company is creating a free to use Start button in its familiar position at the bottom LHS of your screen. It will have all the usual Start menu functions, e.g Shut Down, Run, Search, etc.
    Stardock CEO Developing Start Menu App for Windows 8
    If this is available for the launch of Windows 8 then I'd definitely consider it as a viable alternative to Win7. Wolvers posted a link that showed the advanced features Win8 will have that MS haven't included in previous operating systems.
    And for those of you who dislike the ribbon perhaps somebody will modify the registry to disable or hide it if you decide that you don't want it on your screen.
  11. Jakeway
    Jakeway Member
    Sep 4, 2006
    348
    +25
    So glad the start menu is being address by someone. It seem so stupid that MS dont just give you the option.
    Anyone know how much is Win8 going to cost?
    Just a thought is there isnt that much added to the desktop mode and I dont think it is going to be worth me buying a copy for more than £50.
  12. TheNameIsJambo
    Feb 4, 2011
    5,550
    +1,463
  13. Chuck Norris
    Jul 13, 2011
    5,653
    +3,891
    i'll be skipping this operating system, I find it garbage.
    • Thanks Thanks x 1
  14. Stockholm
    Sep 15, 2004
    2,780
    +631
    What's the difference with that alternative Start menu for Windows 7? It just looks the same to me?
  15. Sartios
    Sartios New Member
    Aug 1, 2010
    3,169
    +228
    Meh.... Windows :rolleyes:
    Not sure why this is in the PC Gaming section though?
  16. TheNameIsJambo
    Feb 4, 2011
    5,550
    +1,463
    It looks better than the Start Menu provided with Windows 8... As there technically isnt one!
    I have no idea what the advantages of ViStart are.. But it works a treat in Windows 8!
