Wii Hd
Discussion in 'Wii & Wii-U' started by postmankevin, May 4, 2007.
  1. postmankevin
    postmankevin Member
    Jan 16, 2006
    16
    hi just got the hd cable and plug it in but all i get is no signal on the tv:lease: is there anyone out there no what i am doing wrong many thanks kev
  2. Moogle
    Moogle Active Member
    Aug 28, 2005
    13,749
    +1,448
    Have you gone into the display options and changed it from 480i to 480p ? You will probably need to connect the original composite cable to do this if you haven't already.
  3. Hi/zuum
    Hi/zuum AVF Table Tennis Winner 06
    Oct 4, 2005
    3,394
    +175
    I take it you mean the component cable. If so, have you got all the colours matched up properly, blue, green & red in the right sockets. go check, 'cause the green in the blue or visa versa can give a blank screen.
  4. postmankevin
    postmankevin Member
    Jan 16, 2006
    16
    they are done ok
  5. Looeewoo
    Looeewoo Member
    May 12, 2006
    477
    +38
    Someone else had a similar problem on here, turned out that their composite lead was still plugged into the TV. Often the composite & component plugs share the same input. He removed the composite lead and the component lead then worked.
  6. Indiana Jones
    Indiana Jones Moderator
    Nov 4, 2003
    23,970
    +2,432
    Is 480p classed as HD?
  7. CAS FAN
    CAS FAN Well-Known Member
    Nov 24, 2003
    29,580
    +3,034
    Nope it's classed as ED (or Enhanced Definition).
  8. Indiana Jones
    Nov 4, 2003
    23,970
    +2,432
    Ah, makes sense it was the title of the thread that threw me :rolleyes:
  9. brain_stew
    brain_stew Member
    Sep 12, 2005
    691
    28
    +38
    I know it might seem obvious but you aren't using the red audio lead in the 3 component video sockets are you?
  10. discostewart
    discostewart Member
    Oct 21, 2005
    796
    28
    +27
    hi,
    i just got my wii and about to hook it up for first time.
    I also have a xbox 360
    this is my first HDTV (panasonic 32" 700) so forgive me if i get all this wrong.
    1 ) People are saying you need to buy a component cable seperately but in the wii box is a cable with the three colours isnt that component ?
    2) So do i connect my Wii using compnent and my xbox 360 using VGA ? is that what people consider best ?
  11. Kahled
    Kahled Member
    Dec 1, 2005
    1,799
    63
    +170
    1. The three colour cable (yellow, red, white) is composite and one of the worst connections to rely on. Component is five connections and needs to be bought seperately. Seems they named the two so close together just to cause that confusion as it is always happening, don't worry about it.
    2. That is one possible way and a lot of people with both do that. Personally I preferred the 360 connection as component also and so use my external amp for component switching with both 360 and Wii connected to that. If you don't have an external switching device then try that and see if you are happy with the results for both machines.
  12. discostewart
    discostewart Member
    Oct 21, 2005
    796
    28
    +27
    thanks
    the xbox 360 doesnt look good in vga ive gone back to component
    which means the wii is stuck oncrappy compositefor now until i can think of something
    i dont have any external amp sadly.
  13. Mark Botwright
    Mark Botwright Moderator & Reviewer Staff Member
    Nov 3, 2006
    7,933
    +1,242
    Why not just buy a component splitter. They can be found quite cheaply so long as you don't mind manually switching between sources.
  14. Indiana Jones
    Nov 4, 2003
    23,970
    +2,432
    What reference level did you set when using VGA and what resolution.
    When I first tried VGA it was horrible but after getting the settings just right it now looks better than Component.
  15. discostewart
    discostewart Member
    Oct 21, 2005
    796
    28
    +27
    i have the brand new Panasonic TX-32LXD700
    to be honest i had no idea what it should be on, it looked best at 640x480 which is a bit odd !
  16. leamspaceman
    leamspaceman Active Member
    Jun 22, 2004
    4,920
    +986
    Same here...VGA is better. It's a little softer but totally noise free. You can really notice it around the orange 'live' logo.
    Stick with it 'discostewart' and use the spare component for your Wii:thumbsup:
