White, Grey or Glass Bead
Discussion in 'Projector Screens' started by bp2411, Jan 23, 2012.
  1. bp2411
    bp2411 Member
    Dec 12, 2010
    213
    +5
    I am hoping to order a new screen asap I currently have a 84" panoview manual white screen, there is nothing wrong with it but I want an electric screen.
    I have been looking at these 2 sellers on ebay & amazon
    platinum147 and Platinum Home Cinema which I am guessing is the same company.
    Has anyone used these before?
    Now I need to decide between white, grey & glass bead. Like I said I currently have a white screen and it is fine but if I would benefit from a grey or g/b screen I will get one of them.
    My pj is a optoma hd700x and I sit 10 feet away from the screen and will be using it for blu-rays and dvds which will be upscaled also 3d blu-rays if this makes a difference.
    Also does anyone know if those screens come with triggers or is it something I have to add-on
    thank you and I apologise for having a couple of threads if it is against the rules.
  2. kbfern
    kbfern Well-Known Member
    Aug 17, 2002
    13,984
    +2,970
    Don't get a glass bead they are bad for hot spotting and narrow viewing angle.
    White is best for batcave situations and grey if your décor is light walls ceilings etc or want to get better blacks and contrast.
    • Thanks Thanks x 1
  3. bp2411
    bp2411 Member
    Dec 12, 2010
    213
    +5
  4. kbfern
    Aug 17, 2002
    13,984
    +2,970
    The grey will be better for you and you should see better blacks and contrast than with your white screen.
  5. Hammond93
    Hammond93 Member
    Jul 28, 2005
    Yes - same company - I've used them - I got the tab-tension version - its great.
    Great customer service too.
    Doesn't have a trigger tho.
    Cheers,
    Marcus
  6. bp2411
    bp2411 Member
    Dec 12, 2010
    213
    +5
    is it possible to add a trigger?
  7. Hammond93
    Hammond93 Member
    Jul 28, 2005
    I'm not sure, as I've never used one, but I don't see a connection for a trigger.
  8. bp2411
    bp2411 Member
    Dec 12, 2010
    213
    +5
    Thanks all for your replies I ended up getting an 84" grey electric version it arrived today can't wait to get it set up.
  9. HMMurdock
    HMMurdock New Member
    Feb 18, 2012
    4
    eek, stay away from glass beaded. They are being phased out by major brands like Da-Lite right now. They flake, are hard to clean and have been surpassed by more recent surfaces in terms of quality for intended image.
  10. One more thing
    One more thing Member
    Feb 15, 2012
    115
    +12
    What the screen like, sounds really cheap? Be interested to hear how the grey screen performs..
  11. Fulltopuk
    Fulltopuk Member
    Oct 24, 2004
    363
    28
    +26
    How is your screen going?
  12. bp2411
    bp2411 Member
    Dec 12, 2010
    213
    +5
    I haven't put it up yet im in the middle of doing my living room which is where the projector is going and it's taking longer than I expected, I will report back once it's up and running.
  13. NorvernRob
    NorvernRob Active Member
    Apr 23, 2006
    2,540
    +576
    I got one of these screens a few days ago and am using it with an Optoma HD67n.
    First thing to point out, there is 1 wall mounting point either side (a standard keyhole hook and drop type) but I would never in a million years trust the screws that come with it. They're only around 35mm long and you need to leave a good 10-15mm sticking out of the wall to hook the mounts onto.
    I used much thicker 50mm screws instead which meant I had to slighly enlarge the 'U' section of the keyhole mounts to enable them to slide in. This was easily done by carefully shaving them with a sharp stanley knife.
    Other than that the screen is great so far, the motor is smooth and quiet and it produces a really nice picture. I'll take some pics the next time I use it.
    Rob
  14. One more thing
    Feb 15, 2012
    115
    +12
    Any idea why the pricing is so random on Platinum 147 eBay site? Some screens are like £1000 and some £100 for Same screen??
  15. TheGoog
    TheGoog Member
    May 12, 2007
    945
    +19
    Would this work hung from the ceiling by chains?
  16. bp2411
    bp2411 Member
    Dec 12, 2010
    213
    +5
    are you sure they are the same and not tab tensioned
  17. NorvernRob
    Apr 23, 2006
    2,540
    +576
    Yes it would, sorry I forgot to mention there are 2 hanging rings built into the casing so suspending it from a ceiling won't be a problem.
  18. NorvernRob
    Apr 23, 2006
    2,540
    +576
    I've just had a look, and their premium tab tensioned screens range from £230 to £2300 but I can't see any differences in the descriptions, the ads are identical.
    They have a 100" for £290 and a 100" for £999 and I can't see any difference other than the cheaper is white and the other grey (but they have an 84" grey listed at £250 so that can't be the reason for the difference)
    Maybe i'm missing something obvious, but a TT 100" electric screen for less than £300 looks a real bargain.
  19. One more thing
    Feb 15, 2012
    115
    +12
    Has anyone here bought a TT screen from platinum? Wondered just how bad the build quality and screen material must be to be sold that cheap?
