Which handbrake presents for Apple TV, Ipad and iphone?
Discussion in 'Apple TV' started by Rikshaw, Mar 21, 2011.
  1. Rikshaw
    Rikshaw Member
    Oct 7, 2004
    41
    I am starting to rip my DVD collect to watch on Apple TV but also on iphone while away and possibly an iPad if I buy one.
    Am using handbrake which is slow but seems to work well.
    I've started by using the 'Universal preset as I will be watching the films on different kit - is this the best way to go or should I use an Apple TV one and accept big files on iphone etc.?
    Help appreciated before I get too far as I dont want to re-do them.
  2. kikapu
    kikapu Member
    Dec 12, 2008
    149
    I am doing the same and I have deceided (rightly or wrongly) to use the atv2 setting the file sizes its creating dont seem that large to me.
    I have adjusted the RF from 20 to 23 for rips of TV or old movies and this makes the files smaller. Any other films will leave at default.
  3. nonsoloinglese
    nonsoloinglese Member
    May 9, 2006
    1,212
    +28
    I wanted to maintain the highest quality setting so used High Profile on Handbrake. So far it works on my iPad, Apple TV 2, but NOT the Apple TV 1 (gutted). I will try it on iPhone later tonight.
  4. bradmill
    bradmill Member
    Jan 5, 2006
    782
    28
    +52
    attached is the settings I use, which can be imported into handbrake. These settings work on ipad,iphone, apple tv 1 +2. It also encodes two soundtracks, 2 channel and 5.1. When played on apple TV, the 5.1 is automatically selected, likewise then using airplay from ipad etc to apple tv.
    hope this helps
    • Thanks Thanks x 1
  5. davenhaze
    davenhaze Member
    Apr 28, 2008
    1,102
    +62
    Would you be kind enough to explain how i import these settings into handbrake??
    Many thanks. :smashin:
  6. bradmill
    bradmill Member
    Jan 5, 2006
    782
    28
    +52
    Save the zip and extract the plist file, then Open handbrake and click up top where it says "presets". Choose "import" and then navigate to the .plist file you saved to your desktop.
    • Thanks Thanks x 1
  7. Mr THX
    Mr THX Member
    Nov 26, 2002
    1,270
    +30
    Heres one to discuss,
    I have a 5>6Gb MKV file on a good quality 720p rip, if I run it through handbrake it shrinks it (as you would expect) but am I loosing much quality for it being reduced in file size?
    What would be the best way to run it through handbrake and keep the file size close to the original? Bigger being better??
    6Tb of storage negates the need to work with small file sizes, but if theres no loss of quality etc etc
    Advice would be helpful on this topic.
    Cheers guys :smashin:
