Gboardman1959
Established Member
Nice one look forward to hearing more of your views
Geoff
Geoff
I just bought and also had drop outs at random but mostly when I was streaming from spotify , Internet radio never dropped out interestingly. , seems my virgin media superhub didnt like doing all the streaming as I added a new linksys ae6900 router to the network on my dealers advice and all is now well , seems the Airdac is only as good as the network it's sitting on , anyway it sounds really good so I'm happy now.
Roadwarrior, did you replace your virgin media hub or were you able to add the linksys to it?
Thanks Roadwarrior! I'll see if I can do the same with my fios actiontec MI424WR.I put the superhub into modem only mode and added the new router , was dead easy and has improved the network no end !
This might be useful to youThanks Roadwarrior! I'll see if I can do the same with my fios actiontec MI424WR.
I just found out about this new AirPlay/UPnP streamer, Myro:Air (Myro Control | Myro:Air - A High-Quality AirPlay Streamer / Receiver), uses a Wolfson WM8741 DAC. Anyone have one yet?
I've got one a brilliant bit of kit a genuine contender to the Arcam Air DacI just found out about this new AirPlay/UPnP streamer, Myro:Air (Myro Control | Myro:Air - A High-Quality AirPlay Streamer / Receiver), uses a Wolfson WM8741 DAC. Anyone have one yet?
At a basic level they have similar functionality - but if its important to you the Myro has only Ethernet/WiFi connection where the Arcam has additional SPDIF inputs.I've got one a brilliant bit of kit a genuine contender to the Arcam Air Dac
