what is the life span of a DVD+R DL disc?
Discussion in 'Computer Components' started by shoestring25, Apr 20, 2008.
  1. shoestring25
    shoestring25 Active Member
    Feb 2, 2003
    3,184
    +179
    excuse my question of already answered of common knowledge as couldn't find anything when did a search
    what is the life span of a DVD+R DL disc do they degrade over time, or usage?
    VHS tapes have a life span but can last for ages of kept properly is the same true for copied DVDs
    PS excuse me if this is in wrong forum
  2. Badger0-0
    Badger0-0 Well-Known Member
    May 30, 2005
    20,591
    +2,008
    Actually, that's a good question, as no-one knows.
    There has been a suggestion that DVD, let alone +R DL, lifespan could be really short.
  3. drummerjohn
    drummerjohn Member
    Sep 2, 2001
    2,366
    +170
    It has been stated (by a scientific report I read about 12months ago) that a quality manufacturer (Verbatim) single layer should last approx 5 years. Thats with it being stored in a dry\dark normal household temperatures.
    Personally, I wouldn't give the dual layer equivalent half of that.
  4. pjclark1
    pjclark1 Active Member
    Jul 19, 2004
    4,411
    +289
    between 3 months and 5 years, depending on manufacturer.
  5. meansizzler
    meansizzler Active Member
    May 11, 2005
    7,419
    83
    +231
    wanting to know this about my 25gb bd-re
  6. shoestring25
    Feb 2, 2003
    3,184
    +179
    so not ideal for long term storage then i take it.
    shame take up alot less space than old VHS tapes but VHS lasts longer so i will keep those
  7. Naqv
    Naqv Active Member
    Oct 15, 2006
    3,055
    +191
    I have disks (DVD-R) about 5years old, really cheap ones (expensive in those days) and they are still fine.
    I have heard the figure of 50years for the disks, but that figure seems an exaggeration, as we are dealing with dye's.
    i most certainly don't think 5 years is correct, at least 15years depending on environment, scratches etc.
  8. jrwagh333
    jrwagh333 Member
    Jul 16, 2007
    430
    +11
    sorry to but in.. but do you think i should wait for Verbatin to release a 50gb BD-RE disk then? or get the EXPENSIVE TDK one? :rolleyes:
  9. Naqv
    Naqv Active Member
    Oct 15, 2006
    3,055
    +191
    Are you talking about 25GB TDK vs 50GB Verbatim? Get which ever you need right now.
    I don't even have a blue-ray writer, as I am waiting for the prices to drop. Now that BR has won the HD war, BD disks should be plenty and (relatively) cheap within 12months+.
  10. jrwagh333
    jrwagh333 Member
    Jul 16, 2007
    430
    +11
    no i got the 25GB Verbatin BD-RE with my burner but have heard that Verbatin are alot better then any other disk maker so i was going to wait untill they released a 50GB BD-RE
  11. springtide
    springtide Active Member
    Oct 7, 2005
    3,684
    103
    +441
    Thats really interesting. Verbatim were claiming about a year or so ago that their "Advanced AZO" DVD+R disks had a 100 year lifespan, and their DVD+RW disks a 50 year lifespan.
    But I've just checked now, and these claims seem to have been removed and even their Archival Grade disks are lacking actual figures...
    http://www.verbatim-europe.com/index/product.php?pid=41&lang_id=1
    "With a dual gold/silver reflective layer, AZO dye and Hard Coat protection, the Archival Grade DVD-R was designed for lifetime use and longevity.
    The dual gold/silver reflection layer with the valuable gold coating provides for the longest possible archival lifetime."
    Which isn't exactly very specific :(
