What is PCM Down Sampling?
Discussion in 'Blu-ray & DVD Players' started by pixel, Apr 25, 2003.
  1. pixel
    pixel Guest
    Should I turn this on it's in my Audio options on my DVD player. I am using a QED SR75 Coax cable to a Toshiba 36ZP18Q 36” widescreen TV.
    Plus there is a digital output option with either bitstream or PCM.
    What is this.....
    thanks :D
  2. pixel
    pixel Guest
    anyone know................? :D
  3. vonhosen
    vonhosen Member
    Jan 6, 2003
    1,836
    41
    +16
    Bitsream output is when your DVD player is sending a Dolby or DTS bitstream signal to an external decoder for decoding.
    PCM (Pulse Code Modulation) down sampling is when your DVD player is down sampling your original PCM signal. If say the original was 96khz & your amp wouldn't accept this down smapling would convert it to 48Khz before sending it out.
    With the digital out option , if you didn't have an amp that would accept DTS or Dolby bitstream you can let the player convert to PCM & send the audio out as PCM
  4. pixel
    pixel Guest
    So do I use it or not?
  5. pixel
    pixel Guest
    bump
    should I use it?
  6. dogastus
    dogastus Member
    Jan 24, 2003
    204
    +6
    If you are feeding the digital audio into the TV set then use the PCM option as the Toshiba doesn't appear to do DTS or Dolby Digital decoding.
    Nigel.
  7. pixel
    pixel Guest
    Emm my ZP18Q says Dolby Digital in the spec......?
  8. Wayne Moule
    Wayne Moule Member
    Aug 4, 2000
    1,333
    48
    +26
    As I understand it,you should use PCM down conversion if you are sending the sound to a non 5.1 decoder,so you get just a stereo out feed.I'm sure Dolby Digital auto down converts to stereo anyway,unlike DTS.
    So if it's going to a non 5.1 DD/DTS TV then you don't need to use it and turn PCM on in your DVD menu.
  9. pixel
    pixel Guest
    thanks
