What does "unsupported audio signal check your device output" mean?
Discussion in 'Home Cinema Buying, Setup & General Help' started by THE AMATUER, Feb 4, 2009.
  1. THE AMATUER
    THE AMATUER Active Member
    Jan 28, 2004
    3,103
    +326
    I have Sky HD. Tonight I changed channel to Setanta 2 (which I subscribe to) to watch the FA Cup reply but there was no picture, just "This Programme is not available".
    The Sony W4500 tv gave a "Unsupported audio signal. Check your device output" message?
    What does this mean?
    thanks
  2. custodian
    custodian Active Member
    May 21, 2006
    4,438
    +493
    I had a similar problem recently and rang Setanta who said that Setanta 2 should not be showing the match in the UK as ITV had the rights. Was the match actually on ITV at the same time?
  3. THE AMATUER
    Jan 28, 2004
    3,103
    +326
    Yes it was
  4. custodian
    May 21, 2006
    4,438
    +493
    So problem solved. Setanta 2 should not have listed that programme for UK viewers as it did not have the transmission rights. It was not a problem with your system.:smashin:
    • Thanks Thanks x 1
  5. THE AMATUER
    Jan 28, 2004
    3,103
    +326
    good stuff, thank you
