micks_address
Hi Folk,
Not sure if i'm missing somethig here or the thing is just plain broken - got a second hand linksys WGA54G to use to connect my blu-ray player to my wireless network. Configured the WGA54G by connecting to ethernet port of my pc.. giving my pc a static IP and access web front end of WGA54G . Gave it IP in range of my router .. according to bridge it can see my network and connect using WEP info entered. When i disconnect ethernet cable though i cant ping the IP address I give the bridge... fed up of it now to be honest. There's also a low level buzz from it and it gets quite warm (might be normal donkt know
Any advice appreciated
Cheers,
Mick
Cheers,
Mick
