Western Digital or Seagate hard drive?
Discussion in 'Streamers & Network Music Players' started by asprint, Nov 21, 2012.
  1. asprint
    asprint Member
    Jan 7, 2009
    661
    +18
    I am looking to get a mains powered 2T hard drive to back up music files.
    There are two manufactures, Western Digital and Seagate that offer drives at affordable prices.
    What have been your experiences with these manufactures is one better than the other or are they both much the same?
  2. larkone
    larkone Active Member
    Apr 21, 2006
    2,451
    83
    +360
    If you are using the drive for backup then its actual use will be very low compared to a live drive so things like different MTBFs will not really come into play, either will do just as well.
  3. GW43
    GW43 Member
    Feb 27, 2005
    1,453
    63
    +140
    I think you should try and audition them as they will sound very different.:devil:
  4. larkone
    Apr 21, 2006
    2,451
    83
    +360
    Especially when you use one of these to connect them
    Cynosure v2 USB Cable
    a snip at $3549 :devil:
  5. GW43
    GW43 Member
    Feb 27, 2005
    1,453
    63
    +140
    Interesting to read that there is a 30-day return for your money back, less a 20% re-stocking charge - over $700 to try it basically.
    I'll have two!
  6. neilmac
    neilmac Member
    Jun 27, 2010
    62
    No idea about seagate but I have have used a wd one connected to my squeezebox touch for the last 18 months with no issues whatsoever.
  7. HMHB
    HMHB Well-Known Member
    Nov 11, 2001
    23,720
    +2,081
    I always use WD drives now and won't touch Seagate ones. Seagate did used to be me drive of choice many years ago but in my opinion they've gone downhill and nowhere near WD as far as quality goes.
    That's all in my opinion of course :)
  8. testdasi
    testdasi Member
    Mar 24, 2011
    226
    +22
    I assume you mean external HDD. In which case, it is cheaper to get a 3.5" enclosure and add an (internal) HDD. And for internal drive, best value is Hitachi.
    As for WD vs Seagate, it used to be Seagate. Now it's WD. I have lost all faith in Seagate after its firmware bug.
