WD TV Live replacement remote
Discussion in 'Streamers & Network Media Players' started by Rother, Mar 11, 2011.
  1. Rother
    Rother Member
    Oct 19, 2010
    76
    +3
    Looking for a better remote for the WD TV, this is the reply i received fron
    Oneforall Tech support
    The following universal remote control models will be compatible (out of the box) with your Western Digital HD Media Player using the setup code 2558 (for video accessories):
    One For All Essence 2 URC7120 (TV, Sat/Cable, PVR, VAC)
    One For All Essence 3 URC7130 (TV, Sat/Cable, PVR, VAC, DVD, VCR)
    One For All Essence 4 URC7140 ((TV, Sat/Cable, PVR, VAC, DVD, VCR, Amp, Tun, Misc)
    The following universal remote control models will be compatible with your Western Digital HD Media Player after the phone upgrade or internet download of the setup code 2558 (for video accessories):
    One For All Kameleon 6 URC-8206 (TV,VCR,DVD,CD,AUD,SAT/Cable)
    One For All Kameleon 10 URC-8210 (TV,VCR,CAS,DAT,DVD,LD,CD,SAT,CBL, VAC,PHO,HOM)
    One For All Kameleon 5 URC-8305 (TV, DVD/VCR, SAT/Cable, AUD, Light)
    One For All kameleon 8 URC-8308 (TV, SAT/Cable, DVD, VCR, PVR, CD, AUD, Light)
    One For All XSight Colour URC8602 (TV, VCR, SAT/Cable, DVR/PVR, DVD/Blu ray, Audio (AMP/Receiver), CD, Digital Media, Combo Units, HOM)
    One For All XSight Touch URC8603 (TV, VCR, SAT/Cable, DVR/PVR, DVD/Blu ray, Audio (AMP/Receiver), CD, Digital Media, Combo Units, HOM)
    One For All XSight Lite URC8610 (TV, VCR, SAT/Cable, DVR/PVR, DVD/Blu ray, Audio (AMP/Receiver), CD, Digital Media, Combo Units, HOM)
    One For All XSight Plus URC8620 (TV, VCR, SAT/Cable, DVR/PVR, DVD/Blu ray, Audio (AMP/Receiver), CD, Digital Media, Combo Units, HOM)
    • Thanks Thanks x 1
  2. planthead
    planthead Member
    May 10, 2005
    1,633
    63
    +212
    Harmony 515
  3. Rother
    Rother Member
    Oct 19, 2010
    76
    +3
    Thanks i had a Harmony, i was not that impressed so i sent it back
  4. xVirus
    xVirus Member
    Jan 25, 2012
    2
    Hello people,
    I have a WDTV and I've lost my remote so I decided to check around and I've found this forum, I followed Rother's (user) advice and bought the ''One For All Essence 4 URC7140''.
    Everything works fine BUT I cant find the button to change the language of the film/movie.
    Can anyone help me with this?
    Thanks in advance
  5. datathief
    datathief Member
    May 16, 2012
    2
    Based on what I read in this thread I got a One For All URC7130, so I thought I'd post about my experiences. It supports the WDTV out-of-the-box, but several functions aren't mapped to keys, or are mapped to slightly silly keys (like pressing "MENU" goes to the home screen).
    To map a function to a key:
    • put the remote in the right mode (SAT)
    • hold the "magic" button until the LED flashes twice
    • press 9-9-4
    • press "magic" again (don't hold it)
    • enter the 5-digit Key Magic code
    • press the key you want to map the function to.
    To reset a key to its default function:
    • press 9-9-4
    • press the key twice
    You'll need these Key Magic codes:
    00040 Mute
    00052 Subtitles
    00053 Display
    00056 Audio
    00116 Green
    00118 Yellow
    00120 Red
    00122 Blue
    00182 Home
    00247 Options
    00251 Back
    00121 0
    00245 1
    00249 2
    00310 3
    00244 4
    00248 5
    00230 6
    00232 7
    00228 8
    00234 9
  6. xVirus
    xVirus Member
    Jan 25, 2012
    2
    Hi datathief,
    thanks for your reply on this post. I see this function works now, but the thing is that you haven't postet de magic key for the 'language button (key)'. Is there a place where I could get this specific key code from?
    King Regards
  7. datathief
    datathief Member
    May 16, 2012
    2
    I found the Key Magic codes by brute force. Press "magic" and enter a 5-digit code, and see what it does.
    Alternatively, you can apparently call or e-mail One For All and ask them if they know the code you want. I don't have contact details for One For All.
    EDIT: I've added the requested codes to my previous post.
  8. mclammer
    mclammer Member
    May 17, 2013
    i use oneforall urc-7120 for wd tv.
    got keycodes from OFA support:
    Video Acc 2558 Western Digital | Model: WDTVLive
    00377 0
    00245 1
    00505 2
    00566 3
    00500 4
    00248 5
    00486 6
    00488 7
    00228 8
    00234 9
    00372 A
    00568 Audio
    00632 B
    00251 Back
    00378 Blue
    00630 C
    00378 D
    00629 Eject
    00565 Enter
    00372 Green
    00438 Home
    00437 Menu Down
    00698 Menu Left
    00313 Menu Right
    00440 Menu Up
    00296 Mute
    00443 Next Page
    00565 OK
    00503 Option
    00503 Options
    00311 Pause
    00311 Pause/Play
    00311 Play
    00311 Play/Pause
    00375 Power
    00548 Previous Page
    00632 Red
    00314 Search
    00246 Search Forward
    00506 Search Reverse
    00425 Setup
    00697 Skip Forward
    00695 Skip Reverse
    00692 Stop
    00308 Subtitle
    00630 Yellow
  9. planthead
    planthead Member
    May 10, 2005
    1,633
    63
    +212
    Have you considered the iPhone app? Works like a charm.
