Washing machine not filling up properly ?
Discussion in 'Home Appliances' started by internetuser, Jul 29, 2011.
  1. internetuser
    internetuser Active Member
    Jul 17, 2003
    3,250
    +214
    Any idea what can cause this before I pull it out and poke round with out much of a clue ?
    It seems the water comes out slowly into the tray were you put the liquid ?
    Which means it takes ages to fill the main part of the machine ?
  2. paulyoung666
    paulyoung666 Active Member
    May 4, 2006
    7,039
    +975
    Do your taps run as normal ?, there is normally a gauze filter where the hose screws onto the back of the machine ...
  3. internetuser
    Jul 17, 2003
    3,250
    +214
    Water pressure is fine.
    It has two hoses going into the back off it ?
  4. MIghtyG
    MIghtyG Active Member
    Mar 1, 2008
    2,777
    +785
    Most water inlets on machines have a filter of some sort afaik, can sometimes get blocked up a little and stop it working properly.
  5. paulyoung666
    May 4, 2006
    7,039
    +975
    Hot and cold fill then , I would check both hoses for filters firstly ....
  6. SBT
    SBT Well-Known Member
    Mar 19, 2011
    7,318
    +2,177
    Have you moved into a new house ?
    Only ask as i have and was having similar problems.Hardly filled and then wouldn't spin out.Turned out the outlet pipe had been capped :blush:
    Called out a bloke for him to pull out a piece of plastic from the pipe :facepalm:
  7. paulyoung666
    May 4, 2006
    7,039
    +975
    or as we found out , the friendly removal company we used connected up the washing machine for us , they got the hoses the wrong way round , hot to cold , cold to hot , took us a while to work out why the washing was coming out red hot at the end of the cycle :laugh:
