Hi, I'm trying to find what size screws are needed to mount a Samsung LE40A656A1F 40" LCD TV?
Samsung told me I needed 4 x M6 screws, but when I popped into Wickes there were numerous different types of M6 screws so I was clueless as to which one's to buy
I have some G clamps to use as it will be hanging from a frame but just need to know which are the correct screws to use with the VESA flat screen extended 25mm G Clamps to fit flush with the TV?
Thanks.
Thanks.
