VW Passat dash warning light
Discussion in 'Motoring Forum' started by ian dem, Sep 11, 2006.
  1. ian dem
    ian dem Member
    Feb 21, 2004
    183
    +4
    Morning all,i need a l'il help if possible.
    I have 2001 VW Passat 2.0 SE & over the weekend a warning symbol has appeared on the display,it has a picture of an engine & in the handbook it says "Exhaust Emissions Warning". :confused:
    In the handbook it mentions the cat covertor and/or lambda fault.
    Any ideas? Its says to take it to the nearest VW dealer,is that really necessary?
    Cheers,Ian
  2. ian dem
    ian dem Member
    Feb 21, 2004
    183
    +4
    Sorry mods please move to motoring!
  3. sdb123
    sdb123 Well-Known Member
    May 17, 2005
    18,473
    +2,239
    If it indicates the CAT/Exhaust...I'd be tempted to take it to any capable garage for a quick diagnosis. Unless of course, your VW dealership does them free of charge :rolleyes:
  4. Daddy k
    Daddy k Well-Known Member
    Jul 19, 2004
    7,747
    +507
    a garage with vagcom will do matey, an indy vw specialist will be best balance of cost/knowledge
  5. F1Boy
    F1Boy Member
    Jul 14, 2004
    196
    +14
    Hi Ian,
    My friends Passat had exactly the same thing a couple of weeks ago - he called VW and they advised it's ok to drive around until you can get to a garage ie not urgent but if it starts flashing then you MUST take it in.
    Probably best to get it checked out :)
  6. mh123
    mh123 Member
    Apr 2, 2005
    677
    +64
    I had this on a Polo TDi about a year ago. Turned out to be a faulty brake-light sensor :lease: which apparently is a known fault...
    ... take her to a garage, you know you wanna!
  7. Dom996
    Dom996 Member
    Jun 3, 2005
    1,061
    +37
    These faults seem to be generally down to airflow sensors, vacuum hoses or idle valves in my limited experience. Try looking at fellow member GolfVR6s site http://www.vwowners.co.uk
    Some of the guys on here seem to know a thing or two. :smashin:
  8. Billo
    Billo Member
    Apr 26, 2005
    513
    +97
    try taking it to E.B. Jones on County Road, Walton.They will be cheaper than Corkhills on the dock road
  9. Boy Named Sue
    Boy Named Sue Member
    Sep 5, 2006
    156
    +4
    Probably worth taking to the garage to make sure. Did you check on their website? There could be morei nformation there...
  10. ian dem
    ian dem Member
    Feb 21, 2004
    183
    +4
    Just to give you an update everyone! :thumbsup:
    I had a diagnostic check done yesterday & the fault was 2 things........ a faulty lambda sensor & a faulty vacuum hose,both replaced by a friend of the family who normally services it for me.Total cost £50 cash!! :rotfl:
    Cheers for your help,Ian :smashin:
