VW Gamma Instruction Manual & Wiring
Discussion in 'Motoring Forum' started by ptammaro_3, Nov 17, 2008.
  1. ptammaro_3
    ptammaro_3 Member
    Oct 13, 2007
    180
    +8
    I just purchased a VW Gamma radio cassette to replace the Beta version in my Polo and was basically wondering if the wiring is going to be exactly the same seeing as the Gamma is the direct upgrade for the Beta? Im hoping itll be nice easy swap.
    Also does anyone know where I could download the instruction manual for this unit as one on ebay I bought doesnt come with them.
  2. Curry Monster
    Curry Monster New Member
    May 18, 2005
    5,387
    +270
    Depending on the age of the set you will either have a 'click lock' system on the newer car ( in the last 3 years or so) or two seperate connectors usually one is brown which is ISO.
    Both will be compatible with your radio (aslong as they match the connector)however you may be missing some connections from your car for the radio to work correctly..
    PM me if you need more help
    • Thanks Thanks x 1
  3. Ayub
    Ayub Active Member
    Oct 15, 2003
    5,960
    +551
    Its the same.:thumbsup:
    • Thanks Thanks x 1
  4. ptammaro_3
    ptammaro_3 Member
    Oct 13, 2007
    180
    +8
    Turns out it was just a direct swap. Thanks anyway.:thumbsup:
