Vista-BT hub connection problems
Discussion in 'Windows' started by jakolantern, Oct 26, 2009.
  1. jakolantern
    jakolantern Guest
    My newly aquired BT Hub cannot be found by my Desktop PC . After 2 sessions of 2 hrs each with BT, they say that its my Vista system which is blocking it's connection,and they have found this frequently before.I have tried the wireless connection and the ethernet cable..The connection when I am on my notebook works fine.[its xp not vista].Am I being conned to shut me up ? I cant cancel my new contract because BT say their equipment is working.
  2. rooney
    rooney Member
    Mar 7, 2004
    506
    +33
    is your pc up to date with antivirus - malware deffanitions etc
    are all your drivers installed correctly ( right click on my computer - properties - device manager- network or network adaptors ) there should be no yellow question marks if there is you are missing a driver and will need to be found
    is windows firewall or defender or user account controll blocking the connection
  3. jakolantern
    jakolantern Guest
    Thanks Rooney.Checked all your points again.Still no joy. Cheers Jack
  4. rooney
    rooney Member
    Mar 7, 2004
    506
    +33
    try it again with the ethernet cable but make sure it actualy goes into the port properly as i hav had in the past the rubber sleave on the cable stops it goin in correctly try that. if no joy with that
    click on start
    click on to run ( or type it into the search bar)
    then type cmd into the run box - then enter
    this should bring up the comand prompt box
    in this box type ipconfig and press enter
    it should give you some numbers a little like these
    ethernet local connection
    ipv address 192.168.1.64
    default gateway 255.255.255.0
    subnet mask 192.168.1.254
    if you dont get any numbers like above but instaed you get one saying
    media disconected its being blocked by something
    please let me now the antivirus you are using/firewall etc
  5. jakolantern
    jakolantern Guest
    Got my 15yr old Grandson on the job.He tested all of your tips to no avail.Then asked me why I needed the HUB.I said so that I could get the faster speed provided by the BT connection.I dont need the wireless part.
    So in no time at all he dumped the HUB and connected and tuned in my old Speedtouch ADSL router,,,BINGO.I am connected and contented again,having gained twice the connection speed compared to my Orange.
    Thanks for your kind help Rooney.
