Virgin internet down?
Discussion in 'Virgin Media Broadband' started by Phill_1981, Jan 17, 2012.
  1. Laubi02
    Laubi02 Active Member
    Jan 30, 2009
    5,743
    +270
    Ahhh can aajyone please help? I haven't been able to get on internet past 2 days via router. The host pc works ok but real slow, did a speed test and ping was about 423!! Dl speed 5mbps ish and ul speed was 0.90mbps
    I can't connect to the router with any of my devices, on my phone, it appears for one second then disappears. Is this due to the poor broadband or is it pc or router related?
  2. Badger0-0
    Badger0-0 Well-Known Member
    May 30, 2005
    20,586
    +2,008
    Phone 150 (if you have a Virgin line) and they'll sort you out.
    There's way too many things it could be and it'll take ages to sort out via a forum.
    • Thanks Thanks x 1
  3. Garrett
    Garrett Moderator
    Apr 21, 2001
    23,126
    +1,609
    I'm getting fed up with Virgin A few weeks back I was loosing my connection for 5 days then since then they I been loosing connections every Monday. Ive contacted them by phone in the past and every time they make out its my computer and have spent over a hour sometimes them telling me to try this, that and the other, and having to repeatedly asked them to repeat what there saying as I cant tell what there saying.
    I then give up on them and miraculously the day after with me doing nothing the connections stable and have no problems for ages.
    With the latest problem today I decided to e-mail them when the net came back online and found of all people you cant e-mail them. This is a provider that provides e-mail yet don't have a e-mail service to contact them.:eek:
  4. Badger0-0
    May 30, 2005
    20,586
    +2,008
    Yes they do Garrett :)
    https://help.virginmedia.com/system...VM_CUSTOMER_TYPE=Cable&CMD=ESCALATION_REQUEST
    Hover over "fault with your service", hit the relevant bar, then down the page hit "I want to make a complaint". You'll see "next" come up at the bottom. Hit that and the next page gives an E-mail option at the top and you fill the form in :smashin:
  5. Garrett
    Garrett Moderator
    Apr 21, 2001
    23,126
    +1,609
    Got thought then although after filling in the form with details and writing a letter the connection went down again:mad:
    I was looking on there forum though and some one wrote in and said why was he going round in circles and could not e-mail them and was told I assumed but someone there of all thing e-mail was not secure and gave them a address to write to to complain.
  6. Laubi02
    Jan 30, 2009
    5,743
    +270
    not strictly about connection, but wondered if anyone else have this problem?
    i tried to run virgin security but said i needed to log on. found out that i dont have an online account (Well, they say my emails/usernames not virginmedia.com0) so i clicked on the button to start a new one. Fill every part of the form but then always fails and says im missing some information
    i have a feeling on the vigin email account section (with the "desire email address) theres a form to be filled but theres nothing on my screen - tried with pc and laptop
    https://my.virginmedia.com/forgot-details/username
  7. Matt_C
    Matt_C Active Member
    Aug 14, 2005
    8,268
    +771
    Ok, maybe a stupid question, but have any of you unplugged the modem/router/superhub and left it for a min, then plugged it back in?
  8. drummerjohn
    drummerjohn Member
    Sep 2, 2001
    2,366
    +170
    Yes - a few times.
    In doing so it wiped my IP\MAC address filters. Same if you do a reset. I reported it VM.
    That's why I only use the Superblub in modem only mode.
  9. LouieBH
    LouieBH Member
    Oct 20, 2010
    22
    this happened to me for most part of last week i gave em a good shouting down
  10. Dony
    Dony Active Member
    Aug 10, 2006
    10,939
    +2,954
    I've had a problem for the last few days with speeds slowing right down to a crawl.
    Just ran a speedtest....read it and weep!!
    [​IMG]
    Normally I get a massive 1mb :rolleyes:
    Called Virgin today and they need to do a line check. Can anyone help me with this....do I remove the face-plate of the main telephone line and connect the ethernet cable directly into something behind the plate? I think that's what I was asked to do. What do I do next?
    My phone connections are awkward to get at, so I want to know what I'm doing before calling the help desk back.
  11. cb1167
    cb1167 New Member
    Feb 29, 2012
    Have you tried going in to your Superhub settings and selecting the option to manually select wireless channel. The auto seek option is awful. I set mine to channel 6 but you might need to experiment a bit. My speed was similar to yours when I joined Virgin. I changed the above setting and all is well now, getting about 30mbps on wireless, which I'm happy with.
