Vintage Pioneer CS-77A speakers - how do I hook up?
Discussion in 'Speakers' started by jessicafirefly, Sep 3, 2009.
  1. jessicafirefly
    jessicafirefly Member
    Sep 3, 2009
    3
    Hi friendly AVForum folks! I'm new here......I just bought a pair of vintage Pioneer CS-77A speakers and have no idea how to hook them up! The wire connectors are blue & white spring loaded (I think). They did not come with any speaker wire. Any how to's and/or suggestions/recommendations on what kind of wire, where to buy & how to connect would be oh-so appreciated! Cheers-Jessica
  2. BlueWizard
    BlueWizard Well-Known Member
    Jun 19, 2007
    14,957
    +2,682
    A photo is worth a thousand words.
    Steve/bluewizard
  3. jessicafirefly
    Sep 3, 2009
    3
    Here's a photie of the back:
  4. sanejo
    sanejo Member
    Sep 17, 2002
    218
    28
    +35
    I'm pretty sure that normal stripped speaker wire is used. In this case Blue = Red.
    I used to have similar Pioneer speaker with a 1971 Pioneer Amp, Cassette deck and turntable. The Speaker connection at the amp end was a proprietry Pioneer connector block. It all got lost in a house move :thumbsdow. It was all very nice stuff and I still buy Pioneer gear.
  5. BlueWizard
    Jun 19, 2007
    14,957
    +2,682
    Defined 'how'?
    You say, how do I connect the speakers?
    What is it you don't understand?
    Is it how the connectors are suppose to work?
    You will notice that printed on the cabinet above the terminals are (+) and (-) marks. That would seem to solve the problem, but since there still seems to be a problem, could you be a little clearer about what you don't understand?
    Are you wondering if these are 'push' terminals or 'screw' terminals?
    It is not really clear specifically what you are asking.
    Steve/bluewizard
  6. jessicafirefly
    Sep 3, 2009
    3
    Thanks for the feedback.
    Yes, I see that the connectors are labeled +/-. What I am unsure of is where to connect the speaker wire to the connectors. Admittedly so, I spent about a glance's worth of time looking at the connectors. I also was unsure whether or not I could use bare wires. Cheers Jessica
