Very old Sony 8MM Camcorder - take to tip or worth anything
Discussion in 'Camcorders & Video Editing' started by MSW, Nov 29, 2009.
  1. MSW
    MSW Well-Known Member
    Nov 23, 2006
    5,377
    +191
    I have a Black, quite big (by todays standards) Sony CCD-TR370E 12X Handy Cam.
    Two questions please,
    Does anyone know how to transfer video from it onto a Computer which only has the following ports Firewire 400 or Firewire 800 or USB.
    Also, once I have transferred the video does anyone know if there is a market for these or, should I just take it to the local tip
    Many thanks
    Mark
  2. MarkE19
    MarkE19 Moderator
    Aug 10, 2002
    15,795
    +2,064
    Basically you need a device to convert the analogue video to digital to get it onto the PC. There are the cheap & chearful (sometimes) USB device such as the Dazzle DVD Recorder or the much better quality devices such as Canopus ADVC55
    There is likely to be a few people with old tapes and a broken camcorder so you should be able to sell it, but don't expect to get much for it, I would gues <£50 but you can always try your luck on eBay.
    Mark.
    • Thanks Thanks x 1
  3. MSW
    Nov 23, 2006
    5,377
    +191
    Thank you much appreciated
