Vegas render PAL to NTSC
Discussion in 'Camcorders & Video Editing' started by bazjo, Mar 8, 2012.
  1. bazjo
    bazjo Member
    Dec 11, 2003
    25
    I have a half hour HD video recorded in using my PAL Handycam which I wish to sent copies to friends in USA. Questions:
    1. Will they be able to play them directly rendered to PAL widescreen DVD at 25fps?
    2. I rendered the file to NTSC DVD at 29.? fps. It appears juddery on my monitor. Would it be smooth on their TVs?
    3. Are there any considerations, other than fps, that could affect their viewing experience?
    Without an NTSC TV, I can't check this. Anyone able to help. Thanks.
  2. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,896
    163
    +3,117
    They should be able to play the PAL version on a computer. Conversion of PAL to NTSC always introduces this sort of problem.
    A laptop with hdmi out to a US TV may also work where a standalone DVD player won't.
  3. Bob++
    Bob++ Member
    Dec 28, 2004
    621
    28
    +61
    I suggest cutting a short clip - choose one with movement in - and e-mailing it to your friend in the States.
