USB Stick to use with XBMC
Discussion in 'Original Xbox' started by doomlord, Jan 17, 2008.
  1. doomlord
    doomlord Member
    Oct 22, 2006
    117
    +6
    For anyone who is after a USB pen drive that works with the Xbox I bought a SanDisk 2GB Cruzer Micro USB 2.0 Memory Flash Drive for £8.49 from play.com a few days ago and it works really well.
    I had been looking for a USB drive to put films and TV shows on to play in XBMC through a controller port on the Xbox. I bought a controller port > USB lead a while back from eBay for softmodding purposes for a couple of pounds.
    Anyway the SanDisk is helpful as my wireless sometimes struggles if the weather is bad and it's a pain 1/2 way through a film for it to exit back to XBMC.
    Does anyone else here play media on their Xbox from a USB stick ?
  2. scumball
    scumball Active Member
    Jan 12, 2004
    5,998
    +387
    I have done. I think pretty much any FAT32 drive will work. I used a Glypth USB HDD.
  3. themoid
    themoid Member
    Oct 23, 2001
    734
    +20
    newbie question. do you use Action Repaly software to put the files onto the USB Stick ? do they have to be zipped / rarred only ?
    cheers
    Stu
  4. scumball
    Jan 12, 2004
    5,998
    +387
    We are using the USB stick with XBMC to watch files from...
    Just copy media files onto a USB stick on your PC and then plug into the XBox via a Controller adaptor (or straight in on the X3 panel) - launch the files from XBMC.
  5. themoid
    themoid Member
    Oct 23, 2001
    734
    +20
    so the usb is formatted so you just drag and drop on the pc, then plug into xbox and it works ok ? hmm, not working for me, any advice ?
    cheers
  6. scumball
    Jan 12, 2004
    5,998
    +387
    Do you have a new version of XBMC?
  7. doomlord
    doomlord Member
    Oct 22, 2006
    117
    +6
    I presume you have already modded your Xbox ?
    If so then have a look at this page
    http://www.xboxmediacenter.com/wiki/?title=USB_Mass_Storage_support_in_XBMC
    If you have a fairly new XBMC running already then the list on that page shows which make and models of USB sticks should work. I couldn't get my Kingston sticks to work however and they are on the 'working' list so be aware of that if that's the make you are using. With the price drops of USB sticks I took a slight gamble with the Sandisk but it works a treat.
    And remember - the USB stick must be no greater than 4Gb or it won't work.
  8. themoid
    themoid Member
    Oct 23, 2001
    734
    +20
    thanks guys. have installed Unleashx, need to work out how to install xbmc. need to set up a wireless network, so have copied the files over from dic but it doesnt want to know, and i ran out of time on the weekend. will try again later !
    cheers
    Stu
  9. bigjb
    bigjb Active Member
    Dec 19, 2006
    3,046
    +216
    If you used AID to install Unleashx as your dash you can also install XBMC as an application.Never used Slayers but i would imagine that has a similar setup.
  10. themoid
    themoid Member
    Oct 23, 2001
    734
    +20
    cheers for the help guys, sorted it with AID earlier. XBMC looks seriously cool :smashin:
  11. mgns
    mgns Member
    Feb 24, 2004
    131
    +15
    Does a 4gb+ usb stick not work at all, or will the xbox only see 4gb of a larger usb drive?
    thanks
  12. frogbog
    frogbog Member
    Dec 25, 2007
    65
    +3
    Just to let you guys know and to help others.
    I've just tested my Sandisk Micro USB (4gb) and its working fine. I'm using the latest version of XBMC dashboard.
    Hope this helps others.
  13. doomlord
    doomlord Member
    Oct 22, 2006
    117
    +6
    Cool. I might get a 4Gb one as I am using the 2Gb one quite a lot.
    Am liking the green light on it too - goes well with the Xbox.
  14. Marcos
    Marcos Member
    Dec 20, 2006
    461
    +13
    Thats the same stick i bought :), except i got it for £5 delivered, price drops are fun
    I cant believe i used to FTP media across and all that hassle, wish i'd known sooner i could just use a USB stick
  15. doomlord
    doomlord Member
    Oct 22, 2006
    117
    +6
    Where did you get it for a fiver ?
  16. Marcos
    Marcos Member
    Dec 20, 2006
    461
    +13
    play.com
    might have been a sale
