Urgent question about Vegas importing
Discussion in 'Camcorders & Video Editing' started by JamesP1701, Mar 1, 2012.
  1. JamesP1701
    JamesP1701 Member
    Jan 1, 2006
    1,347
    63
    +120
    Hi all,
    Appreciate any help on this.
    If I use Sony Vegas to import my HD clips straight off, is there any loss in quality? I don't like dragging and dropping from the camera as it splits the clips up, whereas Vegas can keep them all in one single clip.
    Many thanks,
    James
  2. Chelters
    Chelters Member
    Apr 6, 2011
    617
    28
    +76
    It should have no effect on your clips or the quality of the rendered output as long as you have the project properties set to correspond with your input format.
