Urban Myth: Do Not Lay Plasma TV's flat down???
Discussion in 'Plasma TVs' started by bigfreddiel, Dec 27, 2008.
  1. bigfreddiel
    bigfreddiel Member
    Dec 27, 2008
    3
    I have been told that if you lay a plasma tv flat on its back (or front) the display will be destroyed - or at least damaged. Is this an urban myth or have I been had?
    cheers
    fj
  2. gizlaroc
    gizlaroc Active Member
    Jul 26, 2001
    8,421
    +492
    You can lie them down flat if you are careful, but whatever you do don't transport them lying flat.
    The top piece of glass is very thin, if it flexes it will crack.
    Think about how people carry big panes of glass, it is always upright where the strength is, turn it on its side and it can crack under its own weight.
    • Thanks Thanks x 1
  3. Black Adder
    Black Adder Member
    Jul 16, 2004
    736
    +73
    They don't travel well laying down because they can't bear their flex under their weight and size if subject to a lot of movement/rocking.
    Laying one down temporarily will not destroy it.
    • Thanks Thanks x 1
  4. bigfreddiel
    bigfreddiel Member
    Dec 27, 2008
    3
    So from the replies so far it's the glass that's the problem, so is that true for LCD screens as well i.e. they are relatively thin and may crack if layed flay?
    fj
  5. andrewfee
    andrewfee Member
    Apr 27, 2004
    3,061
    +552
    Almost every screen I've had, has recommended laying the display down flat to attach the stand, so that's certainly not an issue. It's only when transporting the screen you have to make sure it's vertical.
  6. Lin3ar
    Lin3ar Active Member
    Nov 26, 2005
    4,179
    +588
    I am pretty sure LCD's don't have a glass front so I would imagine you can lay them down flat..................and then jump up and down on it and go out and buy a plasma:devil:
  7. bigfreddiel
    bigfreddiel Member
    Dec 27, 2008
    3
    :laugh::laugh::laugh:
    very funny and maybe very true!
  8. Brogan
    Brogan Active Member
    Oct 9, 2003
    7,472
    +492
    The Pioneer manual for my 504 specifically advises you to lay the panel face down when fitting the speakers.
