TV Turns Itself Off & Won't Come Back On
Discussion in 'TVs' started by sounds, Apr 30, 2007.
  1. sounds
    sounds Guest
    I have a Loewe CRT 28" TV. which seems to have developed a problem.
    It switches itself off (onto standby) and won't switch back on straight away.
    When I press the ON button it goes to come on makes a humming sound then goes back to standby.
    I have to switch it off of standby and leave it for a good ficve minutes before it will work again.
    This problem seems to becoming more frequent, especially when I first turn on
    Any ideas on why or a solution?
    thanks
    sounds
  2. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,687
    +1,571
    You need to report back with the model no taken from the rear label if you want a more detailed response.:)
  3. Iancity
    Iancity Member
    Nov 2, 2001
    197
    +5
    Mines done the same :mad:
    Got a 32" zw something cant remember right now, had it for 4 years and 4 months of a 5 year gurantee :thumbsup: .
    Its at the workshop as we speak, mine turned itself off on Friday but when trying to turn it back on nothing happens, just totally dead - i'll let you know what the workshop say.
  4. Iancity
    Iancity Member
    Nov 2, 2001
    197
    +5
    Well apparantly mine had a psu fault ?????
    Should be back next week...............
  5. Goatboyadam
    Goatboyadam Member
    May 9, 2007
    3
    3
    I know this might sound strange but its not your remote that is turning it off is it I have had this fault before at work. Just take out the batteries from it or remove it from the room with the TV. It does sound like a power issue though and it might be going into a stand by mode as a safety feature due to a fault after it has been on for so long, hope you get it sorted.
  6. rjpreston
    rjpreston Member
    Nov 2, 2001
    26
    I have the same issue. How did you get it fixed & what was the cost? Mine's out of warranty :mad:
  7. JayCee
    Jan 20, 2004
    15,687
    +1,571
    That's not to say your set has the same fault...it may be the same or similar symptoms but there are many and varied reasons for them...so I wouldn't put too much store on what it cost Iancity.
  8. Iancity
    Iancity Member
    Nov 2, 2001
    197
    +5
    Mine was just inside warranty so have no idea how much. Its been away 2 weeks but that was mostly waiting for the part I think, its not a complicated job.
