hello everyone i also have a toshiba hd-a3 i need info to make it region free to watch pal discs that i have. thanks
Hi Kingfats
Could you please send PM with info on making HD-A2 to play ALL Disks?
regards
Hi Kingfats,
I've been sulking since HD DVD was killed off and haven't read the HD DVD forums, wish I had now!!
I assume that this works for A20's as well as A2's? If so can you PM me details.
Thanks in advance
Iain
Just ordered an A20.
Kingfats, could you please PM me with the region free info?
Thanks.
Kingfats, I would love to make my A2 region free, could I get that PM? TIA
Hi! Could u please gave the steps on making the HD-A2 region free for DVD?
Thx!
Hi Kingfats,
trying to get my US HD-A2 to be multiregion, Pal compatible! Any suggestions?
Many thanks.
What's going on guys. Could you send me the info on how to make my US HD A2 region free and PAL compatible so I can play some Region 2 UK PAL DVD's? Could you PM it to me KingFats? Thanks.
Also, this modification doesn't affect normal HDDVD playback or NTSC region 1 DVD playback in any way, does it?
Thanks again.
Having it "stuck" on PAL wouldn't in anyway affect the playback of US HD-DVD's, would it (since HDDVD's are neither PAL nor NTSC?)
Even if it gets stuck on PAL but doesn't affect the playback of US HDDVD's that would be fine by me, especially if that's the "worst case scenario," I'll just use the A2 exclusively for HDDVD's and region 2 DVD's and I'd use my PS3 for Region 1 NTSC DVD playback.
So, I'll take that PM.
Thanks again.
Thanks.
Sent you a PM with a quick couple of questions.
Couple I forgot to ask in the PM-
After I install the 1.6 firmware I can go ahead and install the 2.8 firmware (the european one?) Do I install the 1.6, install that other thing, and then install the 2.8? Would that be the proper procedure?
Those steps in the PM you sent me are for playing the DVD's correct, and have nothing to do with installing the region free thing (the region free thing will install automatically just as firmware does correct?)
And if they are steps for DVD playback, they don't have anything to do with playing an HDDVD do they, so I only need to do them when I go to watch a DVD right? HDDVD should play as usual?
That should do it. THanks again.
This hack will also convert PAL and upscale to HD (1080i60, etc.), it won't output in 480 @ 50 HZ and make me have a PAL compatible TV will it?
Sorry for asking so many dumb questions, just want to be absolutely sure before I do it.
