TOSHIBA BDX2100 hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Laubi02, Mar 1, 2011.
  1. Laubi02
    Laubi02 Active Member
    Jan 30, 2009
    5,609
    +247
    hi all,
    looking to buy this but was wondering if this is multi region hackable (mainly for DVDs)
    also, i think the shop im buying from naturally upgrades their players to the latest firmware. does this make the player unhackable?
  2. mentm
    mentm Active Member
    Jun 20, 2008
    3,549
    +397
    AFAIK there is no hack for the toshiba blu ray players.
    • Thanks Thanks x 1
  3. Laubi02
    Jan 30, 2009
    5,609
    +247
    thats a shame, is it me or is there a massive shortage of blu ray players that can be made multi region for DVD playback? well, ones that are around or below £70-£80 :(
  4. mentm
    mentm Active Member
    Jun 20, 2008
    3,549
    +397
    Panasonic or sony are popular choices for multi region dvd but they will cost you a little more than £80 and then you need a special remote to hack them which could cost another £20.
    You may be able to get a philips for that sort of money though. Before christmas my local asda was actually selling the bdp2500 for £60 think it has been discontinued now though. The hack seems to be the same for all models.
    http://www.videohelp.com/dvdhacks/philips-bdp3100/10850
    http://www.videohelp.com/dvdhacks/philips-bdp2700/11220
    http://www.richersounds.com/product/blu-ray/philips/bdp2500-mr/phil-bdp2500
    http://www.richersounds.com/product/blu-ray/philips/bdp2700/phil-bdp2700
    • Thanks Thanks x 1
  5. Laubi02
    Jan 30, 2009
    5,609
    +247
    cheers mate,
    i actually saw the 2500 model in my asda over xmas but the box was damaged and part of the player was exposed so decided against it not realising its actually quite hard to find a cheap blu player with hackable multi region!
