Toshiba 42Z3030 LCD - How do I remove the stand??
Discussion in 'LCD & LED LCD TVs' started by alwi, Jun 10, 2008.
  1. alwi
    alwi Guest
    Hey all,
    I was lucky enough to pick up a Toshiba 42z3030 for a steal off Ebay and have just collected it yesterday.
    As I'm putting it on the wall, I wanted to take the stand off so I can hang it....but I couldn't figure out how to do it. :confused:
    Can anyone help....got a feeling I need a long allen key but not sure what I need to undo.
    Many Thanks. :D
  2. ZX10Rich
    ZX10Rich Member
    Jan 3, 2006
    155
    +21
    Hi, there are 5 allen bolts in the back of the tv, you will need a very long reach allen key though. 3 of the bolts are in a line below the input paneland another 1 on either side below the outer 2. hope this is of some help.
  3. cooperda
    cooperda Member
    Sep 26, 2005
    916
    +71
    Does this picture help of mine being assembled:-
    EDIT - although looking now - this the other bolts on the top piece that connect to the back of the TV
    [​IMG]
    Second picture added - showing allen key:-
    [​IMG]
    Cheers, cooperda
