timer based remote for sky
Discussion in 'Remote Controls' started by ncmoody, Feb 18, 2012.
  1. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I have an old sky box and a DVDR that only has an analogue tuner.
    By connecting them by SCART I can record from the Sky box and use the timer on the DVDR to schedule the recording.
    What I cant do is change the channel on the sky box other than manually.
    Is there a remote control available than can change the channel on a Sky box at a preset time, even better if it can be programmed to do multiple changes - say over a week.
    I have tried an All-For-ONe but the thing is so complicated and almost impossible to control.
    I think the Harmony range can do it but they seem very expensive at £100+ for this task.
    Are there any other solutions out there?
  2. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,291
    +4,488
    Harmonys don't do timers.
    Maybe someone has experience with other makes that do.
    • Thanks Thanks x 1
  3. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I think I have found one
    Sony RM-AV3100
    it has timers but I am concerned because I cannot find a code for controlling a Sky box.
    Anybody got any experience with the AV3100 and particularly do you know if it can control a Sky box and do you have the code.
  4. Crustyloafer
    Crustyloafer Active Member
    Sep 12, 2003
    9,350
    +1,286
    The RTI range of remotes have the facility to program in time and date based events and will be able to do precisely what you require. However if you think the Harmony range are expensive you will not be remotely, no pun intended, interested in these models.
    RTI Product Overview
    • Thanks Thanks x 1
  5. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I would bew better off getting Sky multiroom and a second sky-HD+ box at those prices.
    Thanks anyway.
  6. kdp99
    kdp99 Member
    Mar 29, 2001
    187
    +20
    These are no longer made, but have a timer and will do sky, and they can be got one ebay quite cheap.
    There is a smaller 5 device one that works as well
    http://www.rockabilly.net/files/manuals/URC-8550.pdf
    see for example
    http://www.ebay.co.uk/itm/One-All-T...nics_Video_RemoteControls&hash=item35b9913676
    Sky is code 847. If this code is not in the remotes memory you can download a wave file and use the remotes internal modem to add it to the database (or ring up support and they will play it down the phone to you !)
    • Thanks Thanks x 1
  7. Taz69
    Taz69 Member
    Apr 15, 2002
    1,940
    +34
    Why not buy a Standard Sky+ box mate, that way you have no issues with recording, I may even have an old one here if your local to Bristol to collect!
    Taz
  8. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I have a URC-7780 and am seriously underwhealmed by it.
    When I contacted One-for-All about nissing codes and functions I received an email with some tables in it there were 400 codes for the machines I wanted to conntrol. It took 15 key presses to enter one code, yet they wondered why I thought their responce was stupid.
    As I only want to do one job with this I may well invest as it seems that finding alternative solutions is prooving problematic.
  9. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I have a spare Sky+ box Two reasons for not using it.
    1, it costs £10 per month to activate the recording mode.
    2, it does not record / transfer directly to DVD, you have to copy at real time to a DVDR before transfering to DVD.
    I want to cut out the real time transfer and record directly to s DVDR then the disks can be copied / dubbed at high speed (10 mins. for 4 hours of programmes).
  10. Taz69
    Taz69 Member
    Apr 15, 2002
    1,940
    +34
  11. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    You are correct but they ues 'Guide-Plus+' to control the Sky box. Unfortunatly that was only transmitted on analogue TV, which of course is now dead.
    There is a variant that is tranmitted on ESPN but you need a modern DVDR and of course a subscription to ESPN
    Actually 'Syncro Record' uses the timer on the soource equipment to start the recording on the DVDR. as a standatd Sky box does not have a timer that will not work either.
  12. kdp99
    kdp99 Member
    Mar 29, 2001
    187
    +20
    Just looked on the one for all web site and they no longer do the wave file upgrade ! You can still add the code to the remote but you need a JP1 lead.
  13. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    Interesting I got a WAV file upgrade for my 7780 last week.
    The problem is that there are lots of important functions missing on the equipment I wanted to control.
    Their solution 4 tables of 100 codes, each code requioring 15+ keypresses to implement.
  14. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I won the auction, now lets see if it does the job.
    Not a fan of One-for-All remotes but as this will be limited to one job I thought it worth a try.
    Gone for a Harmony for the multi function solution, so far I am impressed.
  15. kdp99
    kdp99 Member
    Mar 29, 2001
    187
    +20
    I have a working sky wave file if you have trouble.
    Have a look here, the IR programe lets you do all sorts of clever stuff, then use the wav file or a JP1 to upload to the remote.
    JP1 Remotes :: Index
    • Thanks Thanks x 1
  16. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    Sounds good to me.
    JP1 cables for URCs seem thin on the ground - do you know anything about
    JP1.2/1.3 (FLASH) USB Cable for Universal Remotes
    If I PM you with my real email address would you be so kind as to send me the Sky wav file.
  17. kdp99
    kdp99 Member
    Mar 29, 2001
    187
    +20
    just sent you a pm
  18. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I have just responded
  19. rikki2ks
    rikki2ks Member
    May 4, 2006
    965
    +68
    Can't you set the sky box to auto view a channel when you set a reminder?
  20. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    I do not know - but it sounds like something I need to look into.
  21. kdp99
    kdp99 Member
    Mar 29, 2001
    187
    +20
    Its a long time since I tried this but I THINK, this only activates the TV scart in composite on RGB mode, but not 100% sure.
  22. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    In the default settings it does not auto switch simply puts up reminder.
    I can find no methid of setting 'auto view' on a Sky box. Note this is a basic box NOT an HD+ box.
  23. rikki2ks
    rikki2ks Member
    May 4, 2006
    965
    +68
    I seem to remember it being available some years ago? It may well be before Sky + even.
  24. ncmoody
    ncmoody Member
    Feb 15, 2008
    1,453
    63
    +129
    Item turned out to be a 'pig in a poke'
    Anyone know which One-for-all remotes are JP1 compattible AND have timer functions like the 8550
