Thoughts on Fat Gripz (or alternatives)
Discussion in 'Health & Fitness Forum' started by HaRd2BeAr, Sep 12, 2013.
  1. HaRd2BeAr
    HaRd2BeAr Active Member
    Feb 25, 2011
    4,269
    +706
    Hello guys and girls, been looking at these Fat Gripz (love the spelling) and wondered if anyone had used these or alternatives.
    http://www.amazon.co.uk/Fat-Gripz-Ultimate-Builder-Thicker/dp/B005FIS14Y/ref=cm_cr_pr_product_top
    I can't afford to invest in an Olympic weight set and tbh it would be wasted on me.
    Just wondered if it is a good idea increasing the thickness of the bar to increase the use of my forearm or a bad idea? I guess a towel would be a pain to rap around equally and that would bother me.
    I have heard you shouldn't do it for every exercise so maybe just bicep work?
    Thanks in advance for any thoughts :)
    Aaron
  2. Ben-H
    Ben-H Active Member
    Mar 23, 2009
    2,523
    +515
    I've used them a few times when doing bicep curls (with dumbbells or even an EZ bar) and chest press with dumbbells.
    I find they give you a great workout on your forearms (when doing bicep curls) so find they're good to mix up your training with them.
    My protein do their own version of them too which are slightly cheaper -
    Manus Thick Bar Grip Sports & Leisure | Myprotein.com
    • Thanks Thanks x 1
  3. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Thank you Ben :)
    Do you think it would be a good thing to vary a workout and confuse your muscles so to speak?
    Think I will be plcaing an order later.
    Thanks again, much appreciated.
  4. hodgey66
    hodgey66 Member
    Apr 3, 2010
    797
    +42
    definitely make workouts harder so i would recommend! even for chin ups!
    • Thanks Thanks x 1
  5. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Sounds like a fun change to my routine, thanks hodge :)
  6. silent ninja
    silent ninja Active Member
    Mar 15, 2008
    2,247
    83
    +363
    Don't confuse them too much lol
    Vary your workouts a little bit, but not much. You'll never make gains otherwise. You need to get efficient at the exercise pattern to become better at it. Strength is a skill in many ways.
    • Thanks Thanks x 1
  7. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Lol, I just mean compared to what I am used to. A lot of people say you have to lift less using Fat Gripz, but I know weight isn't the be all.
    Just trying to add variety I guess.
    Just wondering if this a good place to start or a gimmick?
  8. silent ninja
    Mar 15, 2008
    2,247
    83
    +363
    It's not a gimmick. The answer, as my economics lecturer always used to say (never say yes or no, it was always a trick question he'd ask) is that "it depends." Lol
    If you want to work your forearms you could do farmers walks or preacher curls. I'm sure fat grips are good too. I did farmers walks today and even my tendons got a workout lol
    • Thanks Thanks x 1
  9. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    I don't have enough room for farmers walks lol
    So it's a case of, it depends on what I do now for forearms as to what benefit grips will have.
    I did reverse grip barbell curls the other day, anything gripping the bar, pull ups, shrugs.
    My impression was that it engages more muscles gripping a bigger bar, but if it is just for forearms then I guess it's not essential. I have slight trouble with my right wrist that gives me a bit of pain so maybe not a good idea?
    Thank you for your thoughts ninja. :)
  10. reiteration
    reiteration Active Member
    Mar 21, 2012
    3,486
    +1,128
    well, I've just ordered the one from myprotein...will let you know my thoughts as and when... :)
    • Thanks Thanks x 1
  11. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Thanks mate, look forward to your thoughts on them. :)
    • Thanks Thanks x 1
  12. reiteration
    Mar 21, 2012
    3,486
    +1,128
    well, they arrived yesterday and are a solid bit of kit..! haven't used them as such - will be beginning of next week before I next to to the gym, tho, I may give them a quick blast tomorrow afternoon with some dumbbells... :)
    • Thanks Thanks x 1
  13. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Sweet, thanks for the update. Get ready to blast those forearms. :D
  14. reiteration
    Mar 21, 2012
    3,486
    +1,128
    well...used them last night for the first time...
    I was doing my pull routine (back and biceps) and I thought I'd start off using them on my bicep workout... on my first set (ez curls) I was able to use my usual weight, but had to use a slightly lower weight on subsequent exercises...but overall I'm impressed and will continue to use them...
    could feel the burn on my forearms, tho, in some ways (because of the reduced weight) - it felt like my forearms were having more of a workout at times...
    • Thanks Thanks x 1
  15. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Thank you mate for your thoughts, so do you feel it took away from the muscle groups you were trying to target?
    Thanks again, much appreciated. :)
  16. reiteration
    Mar 21, 2012
    3,486
    +1,128
    well, slightly...but I was only doing bicep curls with them, and I assume that it will even itself out soon...but then most reviews I've rerad mention that when you start using them you'll use a lighter weight that previously used... :)
    • Thanks Thanks x 1
  17. HaRd2BeAr
    Feb 25, 2011
    4,269
    +706
    Thanks mate, well that's me sold then. :D
    Although I did say to someone they could go on my Christmas list. :eek:
  18. reiteration
    Mar 21, 2012
    3,486
    +1,128
    xmas is too late - think of those missed gains... !! :)
