Thompson SKY HD PSU - SATCURE Capacitors
Discussion in 'Sky Forum' started by paul1999, Oct 12, 2009.
  1. paul1999
    paul1999 Member
    Oct 12, 2009
    17
    Hello
    I recently purchased an exchange psu for my Thompson Sky HD box from a recommended source (not ebay !) and was told that the psu had been refurbished with satcure mark II (uprated) caps.
    It seems to be working ok but it is early days.
    Most of the new caps are black but one (one of the larger ones) is purple. However I think I remember reading on the web that satcure replacement caps are all purple.
    Can anyone who has purchased new caps/mk II caps from satcure confirm whether they are all black except for one of the larger ones being purple ?
    Many Thanks
  2. kenedin
    kenedin Active Member
    Aug 19, 2008
    1,711
    +316
  3. MartinPickering
    MartinPickering Active Member
    Sep 23, 2009
    4,597
    +467
    The Panasonic capacitors are predominantly black with a gold stripe but the telling factor is the beige coloured heat-resistant card between capacitors and heat sink. If that's missing, it's not a SatCure kit and it's not guaranteed. In addition, the shakeproof washer should be correctly fitted underneath the PSU. All information is here: http://www.satcure.net/psu/
    If you didn't buy direct, the approved repairer can give you a password for this web page.
  4. Gavtech
    Gavtech Administrator
    Oct 25, 2005
    18,832
    +4,242
    Martin- Can you check that link please. It takes one to a login screen.
    EDIT - Cross- posted with your edit - OK- Understood.
  5. MartinPickering
    Sep 23, 2009
    4,597
    +467
    I have emailed you a link and a password.
  6. Masteriser
    Masteriser Member
    Dec 4, 2008
    296
    28
    +88
    Martin, once the star washer became known about (around 6 weeks after I installed my exchange PSU from you) I removed the PSU and fitted one.
    However, the heat-resistant card is a much newer development to the repair kit. Having bought my upgraded PSU around 18 months ago is there an option to purchase just the piece of the card, and, if so, how should I fit it (I am assuming it is attached to the board somehow and doesnt just sit there). Seeing as it was so long ago I no-longer have my "keep-Me" email.
    Finally I just want to say thank-you to you and to Michael Dranfield for offering such an excellent upgrade option. As I will tell anyone who will listen on here and on DS, even though I swapped my PSU when my HD box was only seven months old (I was upgrading the HDD and decided I was too lazy to open it up again a year or so later - prevention being better than cure etc), it transformed it from an unreliable donkey to a leopard. No BSODs, no crashes no dual recording or back to back recording problems, no "No Signal" problems and only one missed recording (obviously it has got worse since the new EPG, but I am guessing a repair for that will not available from Satcure any time soon). Some of the improvement is probably down to a better HDD, but I personally think the PSU is the key here (rubbish power in, unstable operation out). It is my opinion that even when new, the original PSU is a pile of noise producing crap and only just upto the job.
    You and Michael have produced an excellent and cost effective repair and upgrade (IMHO) and I salute you both.
  7. MartinPickering
    Sep 23, 2009
    4,597
    +467
    Obviously the older PSUs without the H.R. card enjoy the full guarantee regardless. You can get the card by sending an addressed envelope to the Sales Office, together with a note asking for HTCARD65, your original order number and two unused first-class stamps (or equivalent) just to help cover costs. The girls are mad about horses so, if you enclose a horsey postcard or similar, you'll get their attention! ;)
    The card is simply slid down between the heatsink and capacitors. You can use a couple of dobs of glue if necessary.
    I can probably locate your order number if you email me details.
  8. paul1999
    paul1999 Member
    Oct 12, 2009
    17
    If you didn't buy direct, the approved repairer can give you a password for this web page.[/QUOTE]
    Hi - I purchased from an engineer listed on Satcure website - I can provide name if it helps. Would he be an 'approved' repairer as I cannot get access to link ?
  9. MartinPickering
    Sep 23, 2009
    4,597
    +467
    If he's listed then he's "approved" - until such time as he does something naughty and gets removed!
  10. Reeflodge
    Reeflodge Member
    Sep 16, 2009
    15
    4
    I dont suppose anyone has a spare HT Card they could send me?
    I have just carried out a repair on a TV PSU and I would like to protect my new capacitors that are right next to a heat source?
  11. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,687
    +1,571
    If the original capacitors were mounted next to a heatsink and you've replaced them with 105 degree caps it's not needed.
  12. MartinPickering
    Sep 23, 2009
    4,597
    +467
    It's good to know that someone knows so much more about this subject than I do. After all, I merely spent my teenage years (from age 10) repairing TVs, three years at university, ten years at GEC as a design engineer, three years as a reliability laboratory manager, three years investigating component failures at Siemens, three years as Q.A. Manager at Brother, three years repairing 25,000 satellite TV receivers, as well as writing books on the subject and supplying repair kits for more years than I care to remember.
    So, reflecting heat away from the capacitors won't extend their life? I learn something new every day.
    By that same thinking, I don't need the heat shield around the exhaust pipe of my motorbike so I can throw it away and get rid of that extra weight.
  13. JayCee
    Jan 20, 2004
    15,687
    +1,571
    Gawd, you're not shy are you!
    Of course I don't dispute that, and I suspect you know that fine well.
    My point is that the original Thompson psu and others where space is at a premium and components are crammed next to each other do benefit greatly from such heat reflecting shields.
    In this case the OP is asking if he should fit one in a Tv psu where there's likely to be a good bit more space between components and where there was no shield originally fitted by the manufacturer.
    As long as he fits good quality high temp, low ESR caps they'll probably outlive the rest of the set and certainly last a lot longer than the poor quality ones originally fitted.
  14. MartinPickering
    Sep 23, 2009
    4,597
    +467
    Take a look at this Samsung TV that I repaired.
    The SatCure Blog 189
    Before I replaced the cover, I slipped a heat resistant card between capacitors and heatsink. It was a tight fit. In my opinion, the capacitors will last longer because of it.
    "Reeflodge" doesn't state the make or model number of his TV but, if it's as badly designed as this Samsung, it might benefit from having the card in place. I realise that professional repairers don't want the repair to last too long but, if it were my own TV, I'd certainly do a "belt & braces" repair.
  15. Stevenage Neil
    Stevenage Neil Active Member
    Jul 14, 2008
    9,524
    +892
    Being "Old school" I'd have used foil backed asbestos.......:laugh:
  16. MartinPickering
    Sep 23, 2009
    4,597
    +467
    I sometimes wonder how I survived. We had asbestos string wrapped around the kettle handle and the 150 Watt soldering iron; the garage roof was boarded internally with asbestos sheets; I would blow out asbestos dust from my brake shoes; The Bunsen burner flame mesh had asbestos embedded in it; the physics teacher let us dip our fingers into a bowl of mercury before he set up the "dancing coil" trick, that vaporised mercury in the classroom; I had a "maze game" that used mercury and I had my teeth filled with the stuff!
  17. Stevenage Neil
    Jul 14, 2008
    9,524
    +892
    Makes you wonder how we survived! (I remember "playing" with mercury at school, and leaving plenty of the stuff in the grooves of our desks!)
  18. Smurkenstein
    Smurkenstein Member
    Sep 23, 2006
    524
    28
    +30
    Aye, I have all that stuff (well, not the fingers in the mercury). My dentist wants to pull my shiny terminator fillings out and replace them with resin (and to charge me a fortune).
  19. nsewell
    nsewell Member
    Mar 23, 2013
    242
    28
    +47
    Sigh,
    Now your only allowed to play with a few drops of mercury sealed inside a glass bottle in school.
