Peahead1977
Established Member
Hi hullmackem, I'm getting the same amount of image retention as you, I just think its a side effect of plasma technology. It is annoying but not permanent
Hopefully they do get better over time, but I'm still happy with the overall pic quality and 3d. It's better than my last LG the pk590
hi.this is some realy good settings,i have trie and tried to find the good pic for me and those work very well for me thx.but have you done a new calibration?Hi all, I got one of these TVs last thurs, so after a couple of days I decided to calibrate. I use the i1 display 2 with chromapure software. I only done it fast and these are my settings.
Ratio just scan
Picture mode expert 1
Contrast 80
Brightness 44
Sharpness both 50
Tint 0
Dynamic contrast off
Noise reduction off
Gamma medium( sits at 2.2 til 90 ire)
Black level low
Film mode on
Color gamut wide ( my own preference)
Edge enhancer off
Color temp warm
Method 2point
Red contrast -15
Green contrast o
Blue contrast 4
Red bright o
Green bright o
Blue bright o
20 point ( only in 10 increments) will be re calibrating in 2 weeks
(rgb)
0 -2,0'-7
10 -2,0,-6
20 3,0,4
30 3,0,9
40 -1,0,10
50 0,0,3
60 -2,0,23
70 -5,0,9
80 0,0,0
90 -8,0,25
100 5,0,20
Color management system
Red color -2 tint 6
Green color -4 tint -3
Blue color -6 tint -15
Yellow color -4 tint 1
Cyan color -5 tint 1
Magneta color o tint 6
Mc Donald's Calibrations - Home
Hi shield, haven't been able to do another calibration yet, it takes about 3 hrs to do and my girlfriends mum isn't very well at the min so I have lent her my laptop to watch stuff on and my pc doesn't have the revelant software but I am planning on doing it before Christmas just to have it all set up looking good ;-)
shield said:Hi.sorry to hear that,i wish her all the best
but brightness at 44 i tought was a littel dark,so i tok it up to 50,but at 44 dark was dark and not dark grey,i hadd it at 55 before and you see clear difference in the dark scenes,at 55 dark were dark grey,at 50 it was darker but still dark grey at 44 it was dark not grey just dark,but it was a littel to dark for at 44,mayby i just have to get use to it at 44.
when you calibrate did you do it in a normal light environment or completly dark?
Peahead1977 said:I'll have to check on B&Qs website and see what it has until I work out what lighting I want. Does it make that much of a difference and is it not too bright in ur room?
I gave in and bought these from eBay. LED MOOD LIGHTING IDEAS TV BACK LIGHTS COLOUR CHANGING for £27. 2x15in light bars and remote to change colors. Will give a review when received
