The iPad Jailbreaking & iPad FAQ thread.
Discussion in 'iPad Forum' started by Theydon Bois, Oct 11, 2010.
  1. lampard1983
    lampard1983 Member
    Feb 12, 2009
    990
    +38
    But not for ipad 2
  2. Bob
    Bob Active Member
    Mar 14, 2007
    1,340
    +268
  3. lampard1983
    lampard1983 Member
    Feb 12, 2009
    990
    +38
    • Thanks Thanks x 1
  4. Azzin
    Azzin Well-Known Member
    Nov 5, 2005
    23,860
    +3,078
    What makes you say that?
    I'm not saying your're wrong BTW, just curious. :smashin:
  5. lampard1983
    lampard1983 Member
    Feb 12, 2009
    990
    +38
    "GUnitJC: @comex does this mean jailbreakme 3.0 is out now since you just had jailbroken the new iPad 2?
    Comex: @GUnitJC No, it will take some work to package it into a jailbreak. Same deal as i0n1c."
    "Judging by his past releases, the jailbreak wont be out anytime soon, or at least not until Comex has ironed out all the issues and bugs before making it public. We also don’t have much details on whether the exploit used is a userland, or kernel based. If its the earlier one, then surely we can see something on the lines of version 3.0 of JailbreakMe, ready to untether all devices, including the new iPad 2 on iOS 4.3."
  6. mickie mackie
    mickie mackie Member
    May 27, 2008
    513
    +14
    hi there a friend of mine is running his ipad on 4.3 can this be jailbroken yet
  7. chukwe
    chukwe Active Member
    Aug 15, 2009
    3,893
    103
    +308
    Yes, but only tethered jailbreak with PwnageTool for Mac or Sn0wbreeze for windows
  8. mickie mackie
    May 27, 2008
    513
    +14
    is it easy to do, i've got to do it for him i don't want to brick it for him i did mine using limera1n
  9. chukwe
    Aug 15, 2009
    3,893
    103
    +308
    If I were you, I'll leave jailbreaking it until untethered jailbreak is out.
    It might come out anytime soon. Be patient and watch this space.
    I'm in the same boat with your friend
    • Thanks Thanks x 1
  10. mickie mackie
    May 27, 2008
    513
    +14
    will do thanks
  11. D-an-W
    D-an-W Member
    Sep 23, 2006
    1,685
    +152
    Anyone have any problems Jailbreaking 4.3.1 with Pwnagetool 4.2? Errors 1600 & 2 appear (Not on same attempt) and stop me in my tracks!
    4.3 was a bit fiddly but got it sorted, I can't get 4.3.1 to play nice however!
    It must be an issue with the custom firmware I created as 4.3.1 official works just fine.
    All sorted, sourced files elsewhere and used RamDiskFixer 1.7.2 that was just released.
  12. Turb007
    Turb007 Active Member
    May 16, 2004
    2,686
    +250
    how is the JB ? whats useable and whats not ?
    thanks
  13. Bigmonty69
    Bigmonty69 Member
    Jan 7, 2004
    756
    +60
    Well it's not useable on the Ipad 2 :thumbsdow
  14. Turb007
    May 16, 2004
    2,686
    +250
    Yeh ..different bootrom on the 2 apparently ..hopefully wont be too long ...fed up with the stock apple folders and having to close apps one by one :boring:
  15. winka45
    winka45 Member
    May 3, 2007
    615
    +21
    Hi all, Im on iPad 3.2.2 Id like to update my jailbroked pad to 4.2.2
    Is there anyway to get that update rather than the new 4.3 which I dont really want yet.
  16. D-an-W
    D-an-W Member
    Sep 23, 2006
    1,685
    +152
    It's fine, I just need the Folder enhancer updating to support 4.3.1 (Works fine in 4.3). Celeste isn't supported because Action Menu doesn't support >4.2.1 but thats not a problem for me.
    winka45, only if you have the SHSH files for the firmware you want to use saved on Cydia.
  17. Cloysterpeteuk
    Cloysterpeteuk Active Member
    Feb 5, 2005
    2,889
    +329
    Crap.
    ipad crashed on me tonight while watching iplayer, damn thing went into recovery mode, only way I knew to fix it was to restore it with itunes so now i'm on 4.3 so my jailbreak has gone bye bye.
    But of a pain but at least the ipad is working and i've gained a few features since I was on 3.2 before.
  18. chukwe
    Aug 15, 2009
    3,893
    103
    +308
    If you don't have the ECID SHSH for your iPad save on your computer or Cydia, any update will go straight to iOS 4.3
  19. chimpton
    chimpton Member
    Apr 4, 2006
    487
    +26
    Could you not d/l the 4.2 ipsw from elsewhere then do a restore thru iTunes?
  20. chukwe
    Aug 15, 2009
    3,893
    103
    +308
    That's what you do download the 4.2 ipsw, but you also need the ECID SHSH for 4.2 of your iPad saved.
    Because during any update, apple always do a check to verify that you are updating to the current firmware. A way of catching jailbreakers.
    But if you've your ECID SHSH saved on your pc or cydia, you can trick apple to believe you're updating to the current firmware
  21. chimpton
    chimpton Member
    Apr 4, 2006
    487
    +26
    So even if you hold shift when pressing restore it won't work?
  22. winka45
    winka45 Member
    May 3, 2007
    615
    +21
    I tried the shift and open a downloaded version of 4.2.2. but when it came to updating it keept giving an error. Im just going to update to 4.3 then wait for a new jailbreak I think.
    Thanks for the advice and info guys, appreciated:thumbsup:
  23. chimpton
    chimpton Member
    Apr 4, 2006
    487
    +26
    well that's a Mod Edit:Swearing removed :thumbsdow
    Yep thanks for the info peeps, looks like I'm in the same boat :facepalm:
  24. mattcafc
    mattcafc Member
    Mar 11, 2007
    293
    +8
    Can you jailbreak iPad 2? It runs the same os as a iPad 1 doesn't it?
  25. RobM
    RobM Well-Known Member
    Dec 29, 2006
    13,114
    +2,185
    Very different hardware though, which is the key to most JB's.
  26. splinters69
    splinters69 Active Member
    Dec 17, 2007
    7,189
    +495
    ipod touch fans forum state there is an untethered jailbreak coming today at 8PM...I guess that is american time though. Middle of the night for the UK.
  27. Azzin
    Nov 5, 2005
    23,860
    +3,078
    5am IF it's genuine....
    Sent from my iPhone using the AVForums app
  28. Jon Weaver
    Jon Weaver Active Member
    Aug 16, 2000
    5,123
    103
    +355
    They have released an unteathered Jailbreak for 4.3.1, but not for the iPad2.. So it seems that whilst 4.3.1 has been 'hacked', the iPad2 still has not.
    Jon
  29. lampard1983
    lampard1983 Member
    Feb 12, 2009
    990
    +38
    iPad 2 has been hacked on 4.3 but comex ain't released it yet
  30. Cloysterpeteuk
    Feb 5, 2005
    2,889
    +329
    Only tethered though, The iPad 2 needs a new bootrom exploit, both shatter and lime rain don't work on iPad 2.
