The iPad Jailbreaking & iPad FAQ thread.
Discussion in 'iPad' started by Theydon Bois, Oct 11, 2010.
  1. Azzin
    Azzin Well-Known Member
    Nov 5, 2005
    23,634
    +2,993
    All done-simples!
    One of the easiest J/Bs-ever! :D
  2. beckford
    beckford Member
    Oct 3, 2006
    234
    +19
    The easiest J/B was jailbreakme.com. This one wasn't bad though
  3. 3rdDegree
    3rdDegree Member
    Dec 13, 2005
    262
    +12
    Should I worry about backing up my SH whatsit files (see, I know nothing?).
  4. Goose74
    Goose74 Member
    Sep 24, 2002
    805
    +13
    Hi Guys
    Im a complete jailbreak newbie. I used greenpoisen to jailbreak my ipad but i dont know if its safe to use itunes or to sync etc. Any advice?
    thanks
  5. Strocky
    Strocky New Member
    Dec 4, 2006
    1,227
    +72
    Stupid question do you need to upgrade to 4.2.1 via iTunes or does greenpoison upgrade you automatically?
  6. chukwe
    chukwe Active Member
    Aug 15, 2009
    3,743
    103
    +300
    iTunes only
  7. Moseley
    Moseley Moderator
    Oct 28, 2007
    4,187
    +621
    You'll be fine, just be careful not to update when a new update is released.
  8. qwerty321
    qwerty321 Active Member
    Mar 20, 2009
    6,876
    +949
    Has anyone used greenpois0n to JB their iPad?
    Thinking about trying it out but want to make sure it works OK.
  9. Goose74
    Goose74 Member
    Sep 24, 2002
    805
    +13
    mine worked fine - just make sure you dont interupt it and give a few minutes during the break
  10. qwerty321
    Mar 20, 2009
    6,876
    +949
    Thanks. Went though perfectly.
    Any idea of where to get some good iPad themes?
  11. Goose74
    Goose74 Member
    Sep 24, 2002
    805
    +13
    no sorry, Im new to all this!
    should i be feeling guilty?!
  12. Azzin
    Nov 5, 2005
    23,634
    +2,993
  13. scw
    scw Member
    Jan 6, 2005
    212
    +4
    I posted this on the iphone thread but there is probably more chance of it getting seen here so apologies for posting here as well. I hope that’s ok?
    I’m fairly new to this ipad jail breaking thing, having only done it once before, so need a bit of an idiots guide if someone could help please.
    Currently I have a 3.2.2 jailbroken ipad with only a couple of apps loaded from itunes and MyWi purchased from Cydia. I also have some music and movies that I have manually added from itunes rather than a full sync.
    I want to go for the latest iOS and jailbreak again so that I can continue using Mywi. As I understand it I must first back up the ipad but I’m not sure of the best/simplest way to go about this.
    There is little on it so I could easily drag everything I want on again but I certainly don’t want to have to repurchase the apps from itunes or Cydia.
    Do I also need to back up Cydia and if so again how do I do this?
    Once I have backed up I’m pretty confident that its just a case of connecting the ipad to itunes and clicking to upgrade to the latest iOS. I then understand that I must download the Windows jailbreak on this thread and follow the instructions.
    How do I then restore my apps (shutterstitch and Mywi) and will I also need to re-enter my settings in those apps?
    Thanks in advance for any help. I’m sure its simple but would appreciate an idiots walkthrough.
  14. chukwe
    Aug 15, 2009
    3,743
    103
    +300
    If you want to disable multi-tasking on iPad FW 4.2.1, you need to SSH into your device
    go to -----------> System/library/coreservices/springboard.app/K48AP.plist
    about half way down in the .plist find the multitasking line and change it from 'true' to 'false'
  15. qwerty321
    Mar 20, 2009
    6,876
    +949
    What benefits are there to disabling multi-taksing?
  16. chukwe
    Aug 15, 2009
    3,743
    103
    +300
    Just in case anyone like me wants to disable multitasking.
    I don't need app running in background on my iPad.
  17. 3rdDegree
    3rdDegree Member
    Dec 13, 2005
    262
    +12
    None, from what I can see.
  18. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,617
    +812
    Did mine OK. Only slight oddity was wifi didnt auto connect after reboot so Loader got stuck; once sorted Cydia was fine. Nothing else seems to be broken...
  19. jerryjal
    jerryjal Active Member
    Nov 30, 2008
    3,059
    +301
    What tweak did you use to disable multitasking on the iPad?
    I tried "disable multitasking" in cydia but that does not seem to be iPad compatible.
  20. chukwe
    Aug 15, 2009
    3,743
    103
    +300
    Post #44 of this thread
    • Thanks Thanks x 1
  21. jerryjal
    Nov 30, 2008
    3,059
    +301
    Should learn to open my eyes! :facepalm:
    Thanks.
  22. chukwe
    Aug 15, 2009
    3,743
    103
    +300
    Another user Cydia App is "ScrollingBoard" ($1.50). It adds the Orientation Lock Icon, Brightness slide, iPod Controls (Previous, Play, Next), Volume Control and iPod Icon on the springboard Dock instead of double clicking home button to access it
  23. NewBeetle
    NewBeetle Active Member
    Oct 19, 2002
    9,718
    +1,222
    My sister has just ordered an iPad 1 from apple yesterday, anyone know what software version is likely to be on it and whether it will be ready for JB'ing?
  24. Azzin
    Nov 5, 2005
    23,634
    +2,993
    Hang on....
    [​IMG]
    :devil:
    Probably....4.2.1, maybe 4.3.
  25. Goose74
    Goose74 Member
    Sep 24, 2002
    805
    +13
    Is there a jailbreak for 4.3 yet?
  26. NewBeetle
    Oct 19, 2002
    9,718
    +1,222
    Chortle chortle:suicide:
    I was assuming the V1 iPads would be existing stock clearing through hence being on 4.2.1
  27. chukwe
    Aug 15, 2009
    3,743
    103
    +300
    Yes, but only tethered jailbreak
  28. Bob
    Bob Active Member
    Mar 14, 2007
    1,339
    +268
    Untethered Jailbreak for 4.3 due to be released this week according to sources on the net. :smashin:
    • Thanks Thanks x 1
  29. Azzin
    Nov 5, 2005
    23,634
    +2,993
  30. Bob
    Bob Active Member
    Mar 14, 2007
    1,339
    +268
