The iPad Jailbreaking & iPad FAQ thread.
Discussion in 'iPad' started by Theydon Bois, Oct 11, 2010.
  1. Theydon Bois
    Theydon Bois Moderator
    Jun 26, 2007
    12,840
    171
    +4,471
    I am tinkering, so please bear with me.
    I will maintain a list of threads for people pointing to FAQ about jailbreaking and other questions.
    Please ONLY post links to threads on this board, no questions. Everything else will be deleted so that only this main post remains, so no questions, thats what the threads are for.
    General iPad Threads
    http://www.avforums.com/forums/ipad/1332153-ios-4-2-beta-2-released.html
    Jailbreaking iPad threads
    http://www.avforums.com/forums/ipad/1336251-about-jailbreak-some-questions.html
    http://www.avforums.com/forums/ipad/1338223-limera1n-jailbreak-ipad.html
    http://www.avforums.com/forums/ipad/1337384-untethered-jailbreak-coming-sunday-10-10-10-a.html
    Others
    http://www.avforums.com/forums/ipad/1188008-ipad-vs-insert-tablet-here.html
    http://www.avforums.com/forums/ipad/1315655-ipad-2-guesses-rumours.html
    • Thanks Thanks x 3
  2. happyhiker
    happyhiker Member
    Jan 3, 2005
    419
    +25
    So has anyone used green poison yet? How do you do it? Can it be undone if you need apple look at yer iPad? Will it work when 4.2 comes out for iPad or will it need another release ( I know it's a rom hole they used but does that mean it stays jb after a firm ware upgrade)
    None of the links above seemed to answer these questions, unless i'm blind, and I am get on a bit, so maybe I missed them.
  3. Azzin
    Azzin Well-Known Member
    Nov 5, 2005
    23,647
    +3,001
  4. Theydon Bois
    Jun 26, 2007
    12,840
    171
    +4,471
    For those wondering why others Jailbreak, this post by Abraxus gives a good indication why in this thread:
    http://www.avforums.com/forums/ipad/1350474-location-services-not-working-after-jailbreak.html
  5. the porter
    the porter Active Member
    Dec 15, 2004
    4,261
    +623
    redsn0w has been released well the new version and apparantly works with ipad 4.2 beta but i have just tried it i have cydia on my ipad but it just opens and closes any ideas?
  6. Sy1441
    Sy1441 Active Member
    Apr 10, 2005
    3,901
    +202
    Same issue here.
  7. Azzin
    Nov 5, 2005
    23,647
    +3,001
    Hi all,
    My son's just bagged himself an iPad running 3.2.2 and has tried jailbreaking it using Likera1n, but when he reboots it the Limera1n icon is white.
    When he clicks it he gets the option to install Cydia, but that times out with a error.
    Is Limera1n the best J/B tool to use on his iPad, or is there a better option?
    Any thoughts/suggestions?
    Cheers.
  8. Azzin
    Nov 5, 2005
    23,647
    +3,001
    Anyone? :lease:
  9. Bob
    Bob Active Member
    Mar 14, 2007
    1,339
    +268
    Well I used Limera1n on 3.2 and I seem to remember it took about 3 attempts for it to install properly. I got the white icon as well. After several reboots it eventually worked.
    Now I'm on 4.2.1 using Redsn0w, tethered but no problem as long as you don't need to reboot or let the battery run down. Even then it's quick to jailbreak it again, you don't have to go through the whole process, you do need access to a computer though.
    TBH a lot of Apps need 4.2 now though so you might be better waiting for the untethered jailbreak.
    • Thanks Thanks x 1
  10. Azzin
    Nov 5, 2005
    23,647
    +3,001
    Thanks.
    Could you install Cydia whiel you had the white LR icon though?
    Now I'm on 4.2.1 using Redsn0w, tethered but no problem as long as you don't need to reboot or let the battery run down. Even then it's quick to jailbreak it again, you don't have to go through the whole process, you do need access to a computer though.[/quote]
    Good point and I'll suggest that to him. :thumbsup:
    Yes-especially as Greenpois0n appears to be coming in an untethered form:
    GreenPois0n Will Be Untethered For iOS 4.2.1 On Release, Will Not Require 4.2b3 SHSH Blobs | Redmond Pie
  11. Bob
    Bob Active Member
    Mar 14, 2007
    1,339
    +268
    No I don't think I could, I can't remember the exact sequence of events, I do remember a lot of rebooting though to get it to "stick".
    I seem to remember it had to be a hard reboot ie turn it off completely and then turn it back on.
    • Thanks Thanks x 1
  12. Azzin
    Nov 5, 2005
    23,647
    +3,001
    Ta. I'll get him to try a series of reboots until he gets a "proper" LR icon and then hopefully he will be able to install Cydia after that.
  13. travid
    travid Active Member
    Oct 18, 2005
    5,024
    +603
    I have an Ipad, can anyone of you kind souls give me the positives for jailbreaking the Ipad?
    Many thanks:smashin:
    Anyone:confused:
  14. jaybro187
    jaybro187 Member
    Mar 7, 2006
    1,536
    +90
    right this is racking my brain and doing them in. Ive just won an ipad and its on 4.2.1 (8C148). ive jailbroken loads of iphones and got latest iphone 4, but how do i do this one? i cant find any programs to do it and when i did find redsnow it crashes in windows leaving the ipad in the download data screen.
    can i downgrade the firmware if this cant be done?
    please help
    jay
    • Thanks Thanks x 1
  15. jaybro187
    jaybro187 Member
    Mar 7, 2006
    1,536
    +90
    annoying me now not matter what i do it keeps crashing in windows at the updating ram and where the ipad has the hard drive pic saying downloading jailbreak data
  16. jaybro187
    jaybro187 Member
    Mar 7, 2006
    1,536
    +90
    done it, i put it in c drive and ran as admin, finally
  17. w3dal
    w3dal Active Member
    Aug 4, 2002
    4,212
    +322
    Just jailbroke mine for SBSettings and some sounds which needs winterboard.
    Anyone setup tethering setup from there iPhone? Seen some programs available on Cydia but only just started looking into it today.
    Dal
  18. beckford
    beckford Member
    Oct 3, 2006
    234
    +19
    Is it still jail-broken when you reboot or power off? Thinking of doing mine!
  19. w3dal
    w3dal Active Member
    Aug 4, 2002
    4,212
    +322
    If it looses battery your need to fire up redsn0w and use the reboot tether option. Takes less than 2 mins.
    My iPhone is running the same for the last month and not had a problem so went for it on my iPad.
    I would go for it mate
    Dal
  20. travid
    Oct 18, 2005
    5,024
    +603
    Anyone:confused:
  21. w3dal
    w3dal Active Member
    Aug 4, 2002
    4,212
    +322
    SBSettings, custom themes, custom sounds, many tweaks to list tbh.
    I only survived running on standard for 5 days, jailbreak all the way it makes it so much more customised and make it your own same with my iPhone was jailbroke as soon as I got it out the box.
    If you don't like it. Restore in iTunes and your back to normal.
    Dal
    • Thanks Thanks x 1
  22. travid
    Oct 18, 2005
    5,024
    +603
    Thanks Dal, lets go jailbreaking:thumbsup:
  23. Azzin
    Nov 5, 2005
    23,647
    +3,001
  24. w3dal
    w3dal Active Member
    Aug 4, 2002
    4,212
    +322
    this is great for people who havent JB'd yet but ill be leaving the redsn0w 4.2.1 version on mine, its been very stable and so far not been caught out on the battery going flat and having to reboot using my laptop.
    its great to see, cos for a while this release looked like it wasnt gonna happen.
    bring on 4.3 :D
    Dal
  25. Azzin
    Nov 5, 2005
    23,647
    +3,001
  26. chukwe
    chukwe Active Member
    Aug 15, 2009
    3,745
    103
    +300
    Have anyone tried JB their iPad FW 4.2.1 with GreenPois0n?
  27. Azzin
    Nov 5, 2005
    23,647
    +3,001
    I'm going to do mine later.
  28. Azzin
    Nov 5, 2005
    23,647
    +3,001
    I'm going in, cover me! :eek:
  29. beckford
    beckford Member
    Oct 3, 2006
    234
    +19
    Just done mine now, working sweet as! Doing my iPhone 4 now. Happy Days :D
  30. chukwe
    Aug 15, 2009
    3,745
    103
    +300
    I've JBed my iPad & iPhone 4 with no issues. I used to have issue with WIFI disconnecting every 30 minutes on my iPad. I upgraded my iPad today to 4.2.1, the WIFI issue seems to have been fixed.
    On my iPhone 4, the Cydia source is partially working. I can't find MyWi, Iconoclasm & shrink in Cydia at this moment
