Tevion 32" LCD
Discussion in 'LCD & LED LCD TVs' started by dirty_leo, May 21, 2005.
  1. dirty_leo
    dirty_leo Guest
    Hi all,
    I'm about to buy a Tevion 32" LCD TV. The price is very reasonable but I don't know anyone owning one to get any comments. If you have one, can you tell me if I should go with it or not? I'm also hesistating between a plasma and an LCD, any comments about that?
    Thanks, :thumbsup:
    - Leo -
  2. Scotty306
    Scotty306 Member
    Dec 7, 2003
    392
    +8
  3. dirty_leo
    dirty_leo Guest
    Thanks mate! :thumbsup:
    So, are you going to go for it?
  4. Scotty306
    Scotty306 Member
    Dec 7, 2003
    392
    +8
    Oh i'm so confused by it all !!
    I nearly ordered this: Diboss DIBLT-27KLF 27" LCD from Amazon for £549
    But then I saw the 32" Tevion,
    But do I need a 32" ?
    I don't really need the 27" !!
    I don't know :suicide:
  5. gradmisi
    gradmisi Guest
    Hi All
    I am also looking at this lcd tv from Aldi, but would like to know if there is a headphone socket connection, which for me is a must have, doesn't say anything in the specs. Anybody know. Thanks.
    gradmisi
    • Thanks Thanks x 1
  6. Scotty306
    Scotty306 Member
    Dec 7, 2003
    392
    +8
  7. Scotty306
    Scotty306 Member
    Dec 7, 2003
    392
    +8
    They do look very similar though!
    [​IMG]
    [​IMG]
  8. gradmisi
    gradmisi Guest
    Hi Scotty 306,
    Thanks for the pics, I can't see them leaving out any previous connections in an updated model.
    Will definitely check it out on Thursday. Thanks again.
    gradmisi
  9. BIONIC MAN
    BIONIC MAN Member
    Jun 26, 2002
    716
    +3
    I Have to say I pefer the Tevion writing in Silver and not Silver/ Back :D
    Wonder how many Aldi with get for each store , I would say not that many
    Also can anyone confirm if there is 2 component connections on back of display :confused:
    :smashin:
  10. EnglishJohn
    EnglishJohn Member
    May 1, 2001
    248
    +6
    Managed to get a copy of the technical specification sheet from medion for the tv, probably hasnt got much more data than is avalible all ready but you might wanna look. :D
  11. BIONIC MAN
    BIONIC MAN Member
    Jun 26, 2002
    716
    +3
    Just printed the Spec's
    So I'm I right in saying that there's only 2 scart sockets and No component connections :confused: , but you can run component if using a component to scart cable :rolleyes: . Also the screen size is only 28" :thumbsdow
    :D
  12. busterdan
    busterdan Member
    Aug 18, 2004
    1,266
    48
    +33
    The Screen size is calculated as a diagonal from corner to corner....so is 32".... I'm not sure about the Component thing though.
  13. benwong
    benwong Guest
    Now that IS an interesting way of doing it.. does anyone else know of another model that's set up in this way? I for one certainly have never come across an LCD screen with the ability to do progressive via Scart..all we need to do is wait for someone to buy it and try a progressive component signal via scart to see how well or IF it works properly.. :thumbsup:
    Ben
  14. sponshagga
    sponshagga Guest
    Is this common with 32" or some kind of way of scamming the public because this really doesn't look so cheap at 28" compared to the price you can get 27" lcd's for! :eek:
  15. busterdan
    busterdan Member
    Aug 18, 2004
    1,266
    48
    +33
    It's a 32" LCD diagonal to diagonal... thats how all screens are calculated...15", 17", 19", 27", 32", 42", 50" etc... all diagonal to diagonal.
  16. Puffer
    Puffer Member
    Mar 20, 2005
    109
    16
    Apart from the size and what connections this set has, this concerns me more as quoted by stu 69 On this other thread post #34
    although he does go on to say :
  17. Lord Lucan
    Lord Lucan Member
    Oct 12, 2004
    +4
    There is a review in this weeks Computer Active.
    Bad points:"Fast moving images can become blurry, no HDMI input"
    Good points:"DVI, HD ready,HDCP compatible".
    Summary:"Amazing price but not oine for the home entertainment purists"
    Hope this helps before you part with your hard earned.
  18. busterdan
    busterdan Member
    Aug 18, 2004
    1,266
    48
    +33
    My experience of LCD's and Plasma's is admittedly limited... but would the blurryness in fast moving images be fairly widespread on most panels unless they had a super fast response time.
    This Tevion reportedly has a response time... grey to grey??? (whatever that means) of 8ms? Is this the same way as say stating 12ms on a PC LCD monitor? Maybe with the larger screen and pixels the blurrying is more visible?
    Also HDMI can be connected via a relatively cheap adaptor to the DVI port?
  19. Puffer
    Puffer Member
    Mar 20, 2005
    109
    16
    Like yourself busterdan my knowledge on these panels is limited to only
    what I've read, but surely if this set has a true response time of 8ms you
    wouldn't think it would suffer from smearing and blurriness anyway
    I could put up with it not being the best looking panel around as your not
    sitting looking at the sets surround, but a definite no to blur an smear
    anyway if it has this problem it would put me off buying one .
  20. BIONIC MAN
    BIONIC MAN Member
    Jun 26, 2002
    716
    +3
    8ms is one of the quickest I have seen for an lcd tv , the PQ should be top notch :thumbsdow
    The only way we will all know is if we buy and try :D . If not any good we all take back to Aldi for refunds :smashin:
  21. fingleburt
    fingleburt Member
    May 10, 2005
    72
    +4
    I'll let you all know on Thursday morning when I buy mine :D
  22. busterdan
    busterdan Member
    Aug 18, 2004
    1,266
    48
    +33
    Yes I agree there is no risk in buying the Tevion... if there are any problems it can go back for a full refund...Aldi's returns policy is second to none really.
    In my case it's looking highly unlikely I get one.... I have been given my orders by my other 'arf.... "We have more important priorities and our existing 32" Widescreen CRT monster is fine" :(
  23. busterdan
    busterdan Member
    Aug 18, 2004
    1,266
    48
    +33
    Missus has had a change of heart... ;)
    Looks like I might be getting one afterall... :clap:
  24. caldersey
    caldersey Member
    May 27, 2005
    HI all,
    I bought one of these form Aldi the other day.
    The picture through DVD is excellent really crisp and sharp with vivd colours, with no blurriness as far as I can see.
    Terrestrial signal (through a digibox) is not so good, there's motion blurr and a bit jaggedy round the edges. This could be because I need to play around with the settings and need to upgrade my scart lead to a better quality one.
    Another (bad) point is that the lamp seems to hum loudly. The pitch of the humming changes depending on which setting you select. Although setting it to 'Full' does seem to stop the humming!?! Has anyone else experienced this or is mine faulty??
  25. sponshagga
    sponshagga Guest
    Quite common on lcd tv's my thomson does the same.
  26. n17ken
    n17ken Guest
    I bought one last week and am very happy with it so far.
    The picture quality from the PC using Media Center is stunning. Which is the main reason I wanted one in the first place.
    No humming from the lamp..... yet.
    Sound quality from the internal speakers is very good all things considered.
    Progressive scan works fine with the scart connectiion from my KIss DVD player.
    There is a headphone socket with its own setting in the sound menu.
    Picture quality from cable is certainly as good as my last 100hz widscreen tv..... and the picture shape remains constant at all times.
    I've been watching some HD movies and some of the sample clips from Miscrosoft and the quality is stunning.
    Buy one while you can :smashin:
    All in all for the price a good buy.... it gets better.
    Wall mount kits are normally about £150+ from Currys, Comet etc. An order card is supplied in the box to buy the wall mount for £29.99 + £4.95 pp.
    Compare that with the high street chains and it all adds up to a very good buy.
    Hope this is of interest.
  27. maxman3d
    maxman3d Guest
    Hi there guys just got one of the TEVION 32 the other day .Still playing at the mo with settings and stuff to get the best out of the TV...
    But not too sure in me mind if I am 100% happy with it as I have a plasma 42 Hitachi front room and love that very much. And the TEVION 32 is for the bed room where I am most of time working .So if I was to compare this to the plasma I would say that the plasma is going to win hands down ,But the LCD was only £749.99 and the plasma was £3330 .But all in all the picture quality is very good but not the best that I have seen .TV very good picture looks very cheap made all so , All so tried on PC very good picture but not on desk top just in games like half life 2 which I tried on the net at time of trying the TV on the computer just to see .. Xbox games running on it don’t look good to me wasted out looking but got new lead on the way MS XBOX HIGH DEFINITION COMPONENT AV PACK PLASMA LCD which I hope will make that better if it don’t then I will be taking back as I think that I could do better to buy a 32 plasma for a little more money..
    Now if I was to give this TV a score out of 10 I think that I would give it...
    8 just because the price is very good and it as a lot to offer...
  28. bsvmedia
    bsvmedia Guest
    Hi All, Thinking about one of these sets myself, but does anyone know if the 2 tuners are analogue or digital (freeview) ?
  29. madfish_den
    madfish_den Guest
    Analogue.
    Are they re-releasing this tv or is it the re-furbs they are selling on (my local adli had a few to sell the other week)
    Having just taken back last years 32" 'hd' lcd from Aldi, i would be pretty wary of this one. Although taking stuff back to Aldi is better than most stores!
    However, out of personal curiosity (and a little check for people if they need to take it back):
    * Could somebody check that you can get a Hd image through the scarts (assuming there is still no component input?)?
    * Also showing a HD image via DVI, does the picture judder? (the old one certainly did) and /or crash when you switch picture formats?
    Denny
  30. roswell_3000
    roswell_3000 Member
    Nov 17, 2006
    2
    It seems these TV's are back onsale again at ALDI. I'm pretty sure I'll buy one on thurs. Reading through the thread has made me pretty determined. Although Lidl are selling one aswell on thurs. The info says that the Lidl one has all extra cables and is wall mountable. Just wondering if the Aldi one is? does anyone know?
