System health check
Discussion in 'Sky, Sky+, Sky HD & Sky 3D' started by johnnyjb, Apr 4, 2007.
  1. johnnyjb
    johnnyjb Member
    Apr 25, 2006
    212
    +4
    Whats the system healthcheck in the system set up.Whats the access code it asks for
    Its ok i found out already!!!!!!!!!
  2. stevebez
    stevebez Member
    Jul 11, 2004
    468
    +13
    pls share ?
  3. johnnyjb
    johnnyjb Member
    Apr 25, 2006
    212
    +4
    If you have a problem and your on the phone with customer helpline they will give you a special pin to enter and it gives you a report or some kinda info I think anyway
  4. pdiddy76
    pdiddy76 Member
    Feb 27, 2007
    214
    +17
    does anyone know if there is a mastercode for this feature?:lease:
  5. wormvortex
    wormvortex Member
    May 29, 2005
    5,205
    +269
    I got bored once and tried guessing the code, didn't go well:rolleyes:
  6. pdiddy76
    pdiddy76 Member
    Feb 27, 2007
    214
    +17
    :rotfl: i thought about but decided not 2
  7. GMT
    GMT Member
    Dec 11, 2006
    178
    +19
    ok, theres a thread elsewhere on these boards in regards with it.
    the system health check will only bring up a load of gobble that you nor i would ever understand.
    basically we as the tech advisors type it into our system which gives us most of the details of your box. status of the hard - drive, whether its been changed etc.
    and also about your signal. also does an automatic lnb reset etc.
    and no there is no "mastercode" even if there was no one would release it coz there would be no point. you would have no clue what the results you get on screen meant unless you had the computer system we use etc.
