surround sound speakers not working
Discussion in 'Home Cinema Buying, Setup & General Help' started by lessthantom, Jun 18, 2008.
  1. lessthantom
    lessthantom Guest
    i got given some goodmans ghc 50 surround sound speakers and sub and ive got them set up but the surround sound speakers dont work only the front right and left.
    tried them rigged up to my
    Wharfedale DS-A243
    also tried it rigged up to my
    philips 24pw6518
    and i get nothing
    just wondering if anyone has any ideas
    cheers
    -Tom
  2. Lion
    Lion Member
    Jul 13, 2004
    1,566
    +101
    you need a surround sound amp. :thumbsup:
  3. Phlog
    Phlog Member
    Mar 7, 2008
    1,349
    63
    +173
    The DVD player would have to have a full set of analogue outputs i.e. six including the sub. Sadly it only as has a pair of audio outputs (plus the SCART).
    The TV set needs a pair of analogue (marked red and white or red and black - for right and left respectively) interconnects to the sub-amplifier - you won't get full 5.1 surround from this obviously. If it doesn't work on the TV inputs try the auxiliary inputs.
    Perhaps the TV needs to be set up via its menus in order to provide a line level output? Worth checking.
    Of course, there is the possibility that the sub-amplifier is faulty. :(
    Hope this help.
  4. lessthantom
    lessthantom Guest
    thanks for the info
    i posted wrong when i plug into the tv i get the same 2.1 audio but ill have a play around and see what happens, but the 6 inputs seems to be a sensible thing
    ill have a look at the tv menu's and what not.
    ive read up and apparently i dont need a amp as it has one already built in or something, im a bit of a noob when it comes to sound, but ill look into it.
    cheers for all your help
  5. Lion
    Lion Member
    Jul 13, 2004
    1,566
    +101
    I could'nt find any info on the goodmans speakers you've got,
    I thought they might just be speakers rather than an amplified system, hence my previous post. :)
    so if the goodmans is a full system has it got any digital inputs ?
    and has the dvd player got a digital output ?
    if so that's the best way to connect them together to get full surround sound. :thumbsup:
  6. Phlog
    Phlog Member
    Mar 7, 2008
    1,349
    63
    +173
    The sub has a full set of amplifiers built in. What it appears to lack is any form of digital input; and your DVD player doesn't have analogue outputs :( So sadly you're stuffed at the moment. But perhaps it does give you a good excuse to upgrade the player? :)
