Superhub firmware update - Now available 7th April
Discussion in 'Virgin Media Broadband' started by nickp8, Mar 30, 2011.
  1. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
    The trial firmware has now been made public. Switch off superhub for 30 seconds and then back on to update.
    Super Hub Firmware Update (R25) 07/04/11 - Help & Support Forum
    After firmware upgrade I reset hub to factory default settings to test. This sets ip flood detection and the firewall on. Below is using a ethernet connection.
    IP flood detection no longer has to be disabled and pingtest.net shows 0% packet loss and grade A line quality with it enabled.
    However the firewall is still causing issues. Some sites that loaded fine before will not load at all with the firewall on. Disable the hub firewall and they load in a second.
    Edit: Turning the hub firewall off is stopping file downloads from working. e.g. http://www.thinkbroadband.com/download.html
    See the linked thread below for more info.
    This is a joke. How did this firmware pass their trial and get made public.
    I have posted the thread below asking for users to be able to roll back to the older firmware. Hopefully if enough users post confirming these problems they will roll it back.
    http://community.virginmedia.com/t5...VM-Staff-Firmware-Rollback-Option/td-p/436907
    • Thanks Thanks x 1
  2. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
  3. sergiup
    sergiup Active Member
    Apr 29, 2008
    3,167
    +584
    Thank you, will do so tonight.
    I still live in hope that the WiFi part of this router will someday be better though.. :D
  4. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
    Read reports the firmware has improved the wifi but I dont use the hubs wifi so not tested that part myself.
  5. Naaktgeboren
    Naaktgeboren Active Member
    Jul 13, 2007
    5,609
    +926
    Any chance of a link to these reports, did not find much of use on google.
  6. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
    • Thanks Thanks x 1
  7. thesilverfox
    thesilverfox Moderator
    Jan 31, 2009
    8,128
    +2,852
    Thread title updated as requested.
    • Thanks Thanks x 1
  8. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
  9. jb66
    jb66 Member
    Jul 8, 2010
    98
    +3
    Mine reboots all the time, I had no option but to get this firmware update
  10. SyStemDeMoN
    SyStemDeMoN Active Member
    Feb 27, 2008
    3,062
    +330
    What the hell is going on !?!?!?!
    Since the FW update I can only get a maximum of 600kbps in newsleecher !!
    speedtest shows I still have 50mb but its crap on nzbs !!
    Also Im getting some failures to download files from websites, keeps saying server reset connection !
  11. SyStemDeMoN
    Feb 27, 2008
    3,062
    +330
    Strange, All back to normal this morning ?
  12. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
  13. SyStemDeMoN
    Feb 27, 2008
    3,062
    +330
    I tried with my firewall on and off, I spent about 2 hours last nite trying everything. I was changing IP's and ports which connected me to my news host, I was contacting them and they were awsome but could not see where the problems lay.
    I was ready to give VM a right ear bashing this morning but I was back to 50mbit with no problems.
  14. nickp8
    nickp8 Member
    Feb 16, 2005
    1,695
    +154
    I meant the server reset connection problem when downloading files from sites. Can you download files from the thinkbroadband link with the superhub firewall on and when off as well.
    Speed issue was probably an issue with your newsgroup provider.
  15. gmangt4
    gmangt4 Member
    Jun 4, 2006
    2
    3
    Hi Nick I tried to download from the link you posted and guess what? With the firewall off the downloads dont start.
    P.S. I am running the "new" firmware.
    • Thanks Thanks x 1
  16. SyStemDeMoN
    Feb 27, 2008
    3,062
    +330
    Found out its VM capping certain ports, 563,7000,8000,9000 all capped.
    Changed to SSL 443 and its working a treat :D
  17. marklones
    marklones Member
    Jul 31, 2011
    2
    i just cant get port forwarding to work on superhub any ideas for port 119
