Streaming options - iTunes library on NATS
Discussion in 'Streamers & Network Music Players' started by BicesterTerrier, Dec 7, 2012.
  1. BicesterTerrier
    BicesterTerrier Member
    Jun 30, 2009
    15
    Had a look at various threads re streaming, but couldn't answer my specific thought.
    I use iTunes for my music library, I have the library on a dual bay Netgear readyNAS (for what it's worth), I currently listen to the music through a PC connected to my TV, audio through the TV.
    I have a Bose iPod dock with an iPod classicc ontaining the entire library for times when I do not want to have the TV on.
    We are about to move house and I want to be able to have music in different rooms (the old house was small enough to hear everything from the lounge). I plan to have the Bose in the kitchen with an audio input to allow me to stream radio from an iPhone/Android, but would like to have an option to listen to the content of the library without turning the PC on.
    I do not have a stereo so would ideally be looking at a self contained unit, or perhaps multiple for different rooms.
    I was looking at Sonos, but can find no information as whether they will access an iTunes library on a NATS.
    Any help gratefully accepted, I'm not a technophobe, just never had to worry before.
    Thanks!
    Rich
  2. rorton
    rorton Member
    Dec 26, 2004
    283
    28
    +30
    Yep, sonos will play from an itunes library on a nas.
    If you go sonos, you wont want the Bose in the kitchen, you'll want to replace it with another sonos :)
    It really is a good system.
  3. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,826
    +919
  4. BicesterTerrier
    Jun 30, 2009
    15
    Thank you both for the very prompt response. Looks like the Bose might have to go to the Office to be used as a PC speaker instead.
    Are there any useful guides on here about Sonos and what I might need, I wasn't blown away by their website.
  5. amcluesent
    Aug 13, 2002
    4,826
    +919
    • Thanks Thanks x 1
  6. BicesterTerrier
    Jun 30, 2009
    15
    Thanks for the links, not sure how I missed them.
