Streaming Help! MP4 Files Stutter When Streamed!
Discussion in 'PS3 Media & Streaming' started by VisibleGuy, Feb 15, 2009.
  1. VisibleGuy
    VisibleGuy Member
    Sep 6, 2006
    529
    +3
    When streaming MP4 files to my PS3 they all stutter. I have been streaming videos to my PS3 for some time now inlcuding MKV's remuxed to MPG's and Divx and WMV etc. I have tried these same files on my 360 and they all stream fine.
    What I think the problem is is that for some reason the file is being streamed to the PS3 at a higher than needed bitrate. I found this out by using a wireless bandwidth meter which checks how fast my PC is uploading to my PS3 when I am straming videos e.g. when I press select and I am streaming 720p MPG it says 6Mb per second and it also says 6Mb per second on the PC. However, when I am straming MP4 files to the PS3 when it says 1Mb on PS3 it says 10Mb on PC which is probably why it is stuttering as my PC is connected wirelessly and can not handle 10mb. Then streaming the same file to the 360 it says 1Mb on PC while when streaming to PS3 it would say 10Mb. PS3, 360 and PC are all connected wirelessly and I know that there is more than enough bandwidth available as average bitrate is 2Mb.
    I have tried PS3 media server and Tversity and same problem on both. The PS3 is on the latest firmware. The same file copied to the PS3's hard drive works flawlessly although I do not want to have to keep doing this so I would appreciate any help guys.
    Thanks.
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 299 MiB
    Duration : 23mn 4s
    Overall bit rate : 1812 Kbps
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : avc1
    Duration : 23mn 4s
    Bit rate mode : Variable
    Bit rate : 1650 Kbps
    Maximum bit rate : 8099 Kbps
    Width : 1280 pixels
    Height : 720 pixels
    Display aspect ratio : 16/9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.060
    Stream size : 272 MiB (91%)
    Writing library : x264 core 66 r1093M 1df50b9
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 67
    Duration : 23mn 4s
    Bit rate : 157 Kbps
    Maximum bit rate : 164 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 26.0 MiB (9%)
  2. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    1. Burn to DVD (DL if required)
    2. Use mkv2vob (if files are mkv/ts) to make files into AVCHD compliant folders, transfer to USB stick or HDD, and play (thus keeping any DTS sound)
    3. Transfer file onto USB stick/HDD directly and play off that once connected to PS3
    4. Buy some homeplugs to increase your available bandwidth.
    5. Wire the PS3.
    6. Get lower-bitrate versions.
    Pick one of the above...
  3. VisibleGuy
    VisibleGuy Member
    Sep 6, 2006
    529
    +3
    Is there really no other option as I have more than enough bandwidth to stream this file and I usually stream 720p movies perfectly fine. It is only MP4 container files that stutter and not MP4 files in a MPG container.
    I have also read up and apparently 2.20 broke MP4 streaming for a lot of people, do you thnk that this is why it is stuttering?
  4. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    Maybe, i seem to remember some people complaining about having to stop and start playback or something to get their sound working correctly.
    If you have more than enough bandwidth then i'd ignore all my options :)
  5. garlik_bread
    garlik_bread Member
    Nov 15, 2007
    465
    +14
    I have exactly the same trouble, and always have.
    I have used Tversity, MediaTomb, FreeNas, WMP and now PS3 MediaServer. All MP4 files stutter badly when streamed to the PS3 on all of the above.
    I have copied some to the PS3 direct and they play 100% OK. All other media types work fine streaming, MPG, AVI, VOB, VIDEO_TS etc. Only MP4 suffers!
    I dont want to copy all the MP4s to the PS3 HDD as there is around 13gb so far, and i just cant be bothered copying them to USB HDD then copying them to PS3. Nor can i be bothered to convert them to a different format.
    I presume its something to do with the PS3 firmware, as i have also read that the 2.2 update broke mp4 streaming for lots of people. I hope that Sony fix this in the next firmware release, but dont hold my breath.
    Cant be a bandwidth issue, as all other media is a-OK.
    tl;dr Me too.
  6. garlik_bread
    garlik_bread Member
    Nov 15, 2007
    465
    +14
    I may or may not have just had a breakthrough!
    Was flicking through the PS3 system settings and noticed "Enable ATRAC". Didnt know what it was so clicked it, ATRAC enabled. Thought i'd try playing one of my MP4 files and lo and behold it played without stutter!
    Can't test any others at the moment as i havent shared off the folder they are all in, but it worked on the one i tested which didnt work previously.
    Can anyone else test to confirm this helps?
    :smashin:
  7. garlik_bread
    garlik_bread Member
    Nov 15, 2007
    465
    +14
    Ignore me, just shared off my mp4 folder and they all still stutter. Seems that the one i tested it on before doesnt stutter as much unless you try to skip through. Balls.
  8. harrinp1
    harrinp1 Member
    Dec 19, 2002
    60
    +3
    I've reported similar issues with x.264 mp4 encodes of DVD's done with handbrake. They work fine locally on the PS3 HDD.
    The bitrate is 2.5Mbps but I see network usage of 25Mbps. If I encode them with web optimized enabled the stutter normally goes away but I still see higher network throughput than is required?!
    HD movies I have transcoded using mk2vob with High Bitrates of 10-20Mbps work fine, and only use the correct amount of bandwidth on the network.
  9. stormy
    stormy Member
    Dec 16, 2004
    2,221
    +142
    Can't really help with your problem I am afraid. :(
    Could you tell me which wireless bandwitdh monitor you use on the PC though please?
    Hmm, could it be wireless errors and resending the data although to be honest 10x seems a bit excessive for that, is the meter reporting correctly?
  10. harrinp1
    harrinp1 Member
    Dec 19, 2002
    60
    +3
    It's a wired connection and I'm using iftop on a mac.
  11. VisibleGuy
    VisibleGuy Member
    Sep 6, 2006
    529
    +3
    Reading up online and it seems that 2.20 broke MP4 streaming for a lot of people. It seems that it is up to Sony to release an update to fix it now.
  12. pxr5
    pxr5 Member
    Dec 28, 2005
    649
    +70
    Yeah I can confirm this. My mp4s have never worked since 2.20. I've tried them at every new PS3 update and still no joy.
  13. -Manuel-
    -Manuel- Member
    Feb 21, 2009
    My conclusion is indeed, that the PS3 player has a bug.
    And yes, after eliminating other possiblities:
    • IP connection (wireless / wired), bandwidth, latency
    • Media server, type, configuration
    • MP4 file itself
    Observations:
    • The stutter starts at 3 minutes at 6Mb/s avarage -> 128 Mbyte of data.
    • Starts with video only, audio fails tens of seconds later.
    • At the moment the stutter starts, the displayed bitrates on the PS3 triples.
    • Shown Bitrate Media Server is 6 Mbs; on the PS3 17Mbs (see attachments
    Has Sony Playstation been made aware of this bug? What was their reaction?
  14. CrispyXUK
    CrispyXUK Member
    Feb 5, 2003
    3,587
    71
    +28
    Has this been fixed in the latest firmware?
  15. VisibleGuy
    VisibleGuy Member
    Sep 6, 2006
    529
    +3
    Nope!:mad:
    I've tested it out and MP4 files still stutter.
    Sony seriously need to get this fixed.
  16. Uridium
    Uridium Active Member
    Jan 29, 2005
    14,352
    +1,879
    Just avoid MP4. there are plenty of other formats that are so much better that are well supported by the PS3.
  17. Garfty
    Garfty Member
    Nov 8, 2008
    65
    11
    Thats not the answer though... Yes there are other formats you can use that will play as they should. But sony market it as a media player that can play mp4's, this was true and is now not... so they've obviously broken something.
    I have over 100 of my dvd's ripped to mp4 (im pretty sure other people have way more than me), and I refuse to go through again converting them to a format just because sony cant fix something.
    I tested it last night, and it's still broken which just means my ps3 will gather dust until sony can sort it I guess.
  18. types474
    types474 Member
    Jun 2, 2009
    14
    4
    Problem is that this also affects xvids too. See attached for the bandwidth used by both a x264 .mp4 run from 15:30-17:30 and a xvid .avi run from 21:00-21:50.
    .m2ts and .mpg files work correctly, using only the bandwidth shown by the PS3.
    Very disappointed v3.00 didn't fix this. :mad:
  19. Uridium
    Jan 29, 2005
    14,352
    +1,879
    I never get stuttering on Xvid avi's using wired.
  20. kBm
    kBm Active Member
    Mar 26, 2008
    7,246
    +1,064
    Im glad i popped back to the PS3 forums, i've been suffering stutter playback for a while. Now i know why! :rolleyes: I've been using usb sticks as a work around.
  21. types474
    types474 Member
    Jun 2, 2009
    14
    4
    I only rarely get stuttering on mp4's and never on xvids. However, both of them use considerably more bandwidth than they used to. I have 2 PS3s and used to be able to stream to both of them simultaneously over my homeplug network. My homeplug network gives about 30Mb/s bandwidth so simultaneous streaming is no longer possible :(
    Just wish they'd fix it. Native MKV support would be nice too but we can live in hope...
  22. runout_mick
    runout_mick Member
    Oct 28, 2009
    2
    I've found a workaround for this.
    If you stream your media with ps3 media server, you can force it to transcode mp4s and it plays flawlessly even at high bitrates (this does, however, use some processor power). In the "transcoding settings" tab, under "misc options" type "mp4" in the box beside "force transcode for following extensions".
    Should be fixed.
  23. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    Sorry to "p1ss on your first post" as it were, but that's kinda old news, it's all in the new Media Guide now, widely known that PS3MS is capable of sorting most unplayable formats...
  24. runout_mick
    runout_mick Member
    Oct 28, 2009
    2
    No worries. Just figured I'd document it, as google hits this thread when you search "mp4s stutter when streamed".
  25. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    Ahh i see, maybe i should add those keywords to the sticky ;)
  26. BenchyUK
    BenchyUK Active Member
    Oct 20, 2005
    17,920
    +1,221
    Is the PS3 still having issues when directly playing MP4's from an external HDD for example.
    Im trying ripit for Mac and its awesome and easy but rips all the movies in MP4 and i dont want to have to re-incode them all
  27. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    PS3™ | Types of files that can be played
    MP4 is a container isn't it, so i guess it's what's inside that counts ?
    Having looked through the other MP4-related threads however, it seems that it's highly annoying to try to get to playback on the PS3...
