Stream laptop screen to TV wirelessly?
Discussion in 'Streamers & Network Media Players' started by chelttown, Mar 25, 2009.
  1. chelttown
    chelttown Member
    Jan 8, 2007
    15
    Is it possible to steam the display of a laptop or PC to a TV wirelessly. I know that you can stream videos and mp3s, but is it possible to stream the actual display?
    Any help on this would be great,
    Cheers.
  2. madmonk3y
    madmonk3y Member
    Dec 11, 2005
    453
    +69
    I've never heard of anything that does this, but then again I'm not the fountain of all knowledge. I would personally err on the side of "not possible"
    Ignore the above check the links. Seems there is such a thing, but you have to buy kit.
  3. chelttown
    chelttown Member
    Jan 8, 2007
    15
    Thanks for the reply :) I was already aware of kit like that, unfortunately it is not what I am looking for.
    What I am really looking for is software to convert the display to a video that could then be streamed, with as little lag as possible. Having to plug the laptop into something defeats the object of being truly wireless.
    Cheers.
  4. chelttown
    chelttown Member
    Jan 8, 2007
    15
  5. sunil1234
    sunil1234 Member
    Dec 5, 2004
    1,266
    48
    +98
  6. stevewillow
    stevewillow Member
    Dec 3, 2009
    Anyone wanting to stream from laptop/PC to TV needs to have a look at SLINGBOX. For around £150 (PC World, UK) or slingbox site for USA ($199). It does exactly what it says on the tin . . .
  7. Subliminal Aura
    Subliminal Aura Member
    Jun 2, 2007
    1,473
    48
    +91
    Well those reviews look a little too critical.
    I've just tried it and think it's got potential
    Hardware used
    WDTV Live upnp client
    Server
    Athlon XP-M 100mbps This failed the athlon wasn't up to the task of transcoding
    My laptop over wifi. Much better results but the CPU was *just* coping 80% utilization with chrome and youtube. What let me down was the network utilization of 40% over wifi (asking for trouble)
    So if you're going to do this make sure your server has the grunt.
    I'm going to try it on overclocked dual/quad machines wired (100mbps LAN) very optimistic about this as my laptop didn't do too badly at all.
    I'll report back later
