Storage Options Scroll 7 inch Touch Screen Android 2.1 Tablet
Discussion in 'Tablets Forum' started by cap8000, Dec 12, 2010.
  1. cap8000
    cap8000 Member
    Dec 12, 2010
    Any user reviews as thinking of buying for £139.99 from play specs look good for price
    Product Description
    The Scroll is a fully featured Mobile Internet Device (MID). It can connect to the internet using the built in Wi-Fi. It’s also a multimedia player capable of 1080P HD video out, view smooth high definition movies on the move or through the HDMI output on your TV. Its just as good with your photos and music too, playing all the latest formats, making the Scroll the ultimate portable multimedia device. The CPU is no slouch either, sporting the latest dual core ARM 11 processor which means its capable of handling HD content & 3D games with ease.
    With the latest version of the Google Android 2.1 Operating System installed, it gives you access to one of the largest libraries of applications (Apps) via the pre-installed Google market app. Whether you use it for social networking sites such as facebook, instant messaging friends via MSN, playing the latest 3D mobile games, watching videos on YouTube, reading E-Books or watching the latest news – everything is covered, in fact there are over 100,000 app’s available now with more being added on a daily basis! (Note: there may be a charge for some apps)
    The Scroll doesn’t leave expansion as an after-thought either, included as standard is
    -- 2 x USB ports for adding your own peripherals e.g external Hard drives.
    -- HDMI out for connection to a monitor or HD ready TV so you can view your movies on the big screen.
    -- Micro-SD slot – so you can expand the storage of your device up to 32GB as you fill it up with movies, games, music & photo’s.
    Processor
    800Mhz ARM11
    Memory
    256MB DDR2 RAM
    Storage
    2GB memory built-in,
    micro SD card
    Expandable upto 32GB
    Software
    Operating System: Android 2.1
    Music,
    Photo,
    Movie,
    Gmail,
    Email,
    MSN,
    Facebook,
    Adobe Reader,
    Google Map,
    Youtube,
    Flash,
    3D Games
    Variety of Downloadable Apps
    Display / Graphics
    7” Resistive touch screen
    Resolution: 800 x 480,
    Aspect Ratio: 16:9
    Full HD 1080P supports MPEG-2, MPEG-4, AVS,H.264,WMV, AVI, MP4, RMVB, FLV, MKV
    E-book support PDF,EPUB,TXT,HTM,HTML,RTF,PDB,DJVU,IW44,FB2,MOBI,T CR
    16 bit G-sensor, monitors & rotates screen through 360deg
    Open GL 2.0 3D support
    Audio
    3 x 1W /8Ω speakers
    Input Devices
    Networking
    WiFi 802.11b g
    Power Supply
    3400mAH Li-polymer rechargeable battery
    Up to 4 hours use
    5V DC-IN
    Dimensions
    Width : 203 mm
    Height 132 mm
    Depth 12 mm
    Aluminium alloy casing
    Interfaces / Expansion
    1 x DC-IN
    3.5mm earphone jack
    5 pin mini USB port
    Full Size HDMI TV-out
    5 pin mini USB host port for USB flash drive, keyboard, mouse (external device connection)
    Warranty / Miscellaneous
    1 Year Manufacturer Warranty
    0.3 megapixel Webcam
    Storage Options Scroll Tablet PC with 7inch Touch Screen, HDMI, Webcam - 51624 Digitalpromo.co.uk
    STORAGE OPTIONS 7" Touch Screen ARM11 2GB Android 2.1 Tablet PC (51624) - dabs.com
    STORAGE OPTIONS 7" Touch Screen ARM11 2GB Android 2.1 Tablet PC (51624) - BT Shop
    Storage Options Scroll Tablet PC - Tablets | Ebuyer.com
    http://www.storageoptions.com/suppor...oll-manual.pdf
    Storage Options Scroll Tablet PC – perfect for xmas « CD-writer.com – the optical perspective
