Squeezebox Receiver doesn't get beyond flashing red lights
Discussion in 'Streamers & Network Music Players' started by Magic Beans, May 14, 2009.
  1. Magic Beans
    Magic Beans Member
    Jun 25, 2008
    1,137
    48
    +49
    Before i burst a blood vessel i thought i'd throw up my "situation" with other more experienced and calmer peeps :mad:
    I've finally just taken delivery of a Squeezebox Receiver to go with my iPod running iPeng with Squeezecentre 7 running on my QNAP.
    All good so far..
    The iPod/iPeng is configured and speaks to the QNAP without issue.
    Still all good. However....
    I can't get the Receiver to appear anywhere. It's plugged in to the mains, connected to a 10/100/1000 network and hooked up to my amp using SPDIF. It's powered on and sits on the flashing red light phase and gets no further.
    My question is where do i go from here? I can't configure it because the controller doesn't see it, it doesn't show as a device on my router and doesn't appear in the "Player" list in Squeezecentre. :confused:
    Help. Please :suicide:
  2. Autopilot
    Autopilot Active Member
    Feb 5, 2005
    6,651
    +956
    You can only setup an SBr in two way's - 1) With the proper Squeezebox controller (not iPeng), or 2) Using a program called Net::UDAP. See here Net::UDAP - SqueezeBox Receiver configuration tool - Squeezebox : Community : Forums
    It's a bit tricky, but it does work (i have done it no problems).
    • Thanks Thanks x 1
  3. Magic Beans
    Magic Beans Member
    Jun 25, 2008
    1,137
    48
    +49
    Thanks for the heads up and the info. :thumbsup:
    I've downloaded the zip file and extracted it. I'm struggling to get the command to run though.
    scripts/udap_shell.pl
    Do i have to change to the "tags" directory only, or all the way in to
    the "scripts" folder? I've tried both, run the command "upap_shell.pl"
    as i was in the scripts directory. A text file came up with details
    about the software etc. however when i type "help" the options aren't
    they should be. I don't appear to be in the UDAP mode
    Any ideas?
  4. Magic Beans
    Magic Beans Member
    Jun 25, 2008
    1,137
    48
    +49
    Just found the executable lower down the page. Now in UDAP mode :thumbsup:
  5. Magic Beans
    Magic Beans Member
    Jun 25, 2008
    1,137
    48
    +49
    Even running the .exe file, when i run the "discover" command it doesn't find the mac address of my SB :mad: It only finds 00:00:00:00:00 on 255.255.255.0
    To say how easy the Harmony was to set up, this has to be one of the most miserable experiences of my life. Thoroughly unimpressed :thumbsdow
  6. Autopilot
    Feb 5, 2005
    6,651
    +956
    Your trying to do something the manufacturer never intended. The SBr is part of the Duet (SBr + SB Controller). The reason SBr's can be bought on their own is so that additional rooms/zones can be added to an existing Duet setup, but they were never really designed to be used on their own.
    The Net::UDAP utility you have is more of a hack, it's not an official piece of software. If you want to use a product in an unorthodox way expect to have to fiddle around a bit.
    IMO you would be better off spending a bit extra and getting a Squeezebox Classic, its well worth extra money, has a nice screen and will work with iPeng and your Harmony remote. You don't need to do anything special to set it up either.
    Otherwise, post on the forum i linked you too. Trust me, it does work, you are probably just not doing something right. Have you tried pressing/holding down the button on the SBr first? If my memory serves me correctly you might have do do that.
    • Thanks Thanks x 1
  7. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,621
    +816
    • Thanks Thanks x 1
  8. Magic Beans
    Magic Beans Member
    Jun 25, 2008
    1,137
    48
    +49
    New day, new mindset. I've managed to find someone who has the controller whch i can borrow for the night. So hopefully it should all be a beautiful memory by tomorrow.
    Thanks for your input guys. Apologies for the grumblings, but no man likes to lose "man points" when setting something up ;)
