Specs for this Kenwood A-82 amp?
Discussion in 'Hi Fi Systems & Separates' started by lersince1991, Nov 28, 2009.
  1. lersince1991
    lersince1991 Member
    Apr 12, 2007
    852
    +11
    I'm about to invest in a seperates system and starting with my dads amp and some floor standing speakers for hi-fi use mainly.
    But I can't find the manual or specs for my dads 'Kenwood Stereo Integrated Amplifier A-82'
    I've looked just about everywhere. Does anyone know of any way I can find this info?
    Luke
  2. alexs2
    alexs2 Senior Moderator
    Nov 13, 2002
    13,911
    +1,710
    Are you sure of the model number?
    The nearest I can find is the KA-92,but no specs available.
    With the quoted marking of 150W on the rear panel you would be looking at about 30-40W/channel.
  3. lersince1991
    lersince1991 Member
    Apr 12, 2007
    852
    +11
    Well I'm not sure of the model number but on the front panel it says KENWOOD stereo integrated amplifier a-82.
    Can't find any other numbers really...
    Heres some photos of the info
    Thanks for the help
    Luke
  4. scorpion88
    scorpion88 Member
    Aug 10, 2008
    1,986
    63
    +178
    Maybe worth contacting Kenwood Direct if you consider it to be of value.
  5. BlueWizard
    BlueWizard Well-Known Member
    Jun 19, 2007
    15,458
    +2,757
    I've found no references or Photos to the Kenwood A-82, but I did find some to the A-85, but I don't trust the power specs on them.
    I did find the owner's manual for the Kenwood A-93, the specs on the amp are as follows -
    DIN at 1khz to 8 ohms = 70w + 70 w
    IEC/NF at 8 ohms = 65w + 65w
    http://inform3.kenwoodusa.com/manuals\midim93.pdf
    Now assuming your amp is two models down from this one, I would expect it to be something like 20w per channel to 8 ohms.
    Searching Kenwood-USA only turns up a reference to the Model A-93. However, models numbers can vary from country to country.
    Kenwood USA model search -
    Kenwood - Home Electronics Owner's Manuals
    However, a search of Kenwood-Germany brought up several similar model numbers under the heading 'Verstarker' and the prefix 'KA-' -
    Kenwood Electronics Deutschland | Produktarchiv > HiFi > Verstärker
    These A-83 and A-85 models must have been extremely rare, or we would at least be able to find some Google-Images of them. There are a very few of the A-85, but they were not helpful in the information they provided.
    I think the best we can do is extrapolate down from the Model A-93.
    Steve/bluewizard
  6. lersince1991
    lersince1991 Member
    Apr 12, 2007
    852
    +11
    Just 20 watts huh...
    I was hoping to run something like B&W DM604 S2's or Monitor Audio BR5's from this amp. if its 20 W then that would be under the speaker systems spec...
    Anyway, thanks for the help, ive email Kenwood but I doubt they will get back to me any time soon...
    Luke
  7. lersince1991
    lersince1991 Member
    Apr 12, 2007
    852
    +11
    Got an email back from Kenwood, its 50w per channel
    Specs sheet is below
  8. BlueWizard
    Jun 19, 2007
    15,458
    +2,757
    In that case, assuming it is working OK, it is probably a very good amp, and should have no trouble with a vast majority of consumer speakers out there.
    The distortion specs aren't fantastic, but they are still very good, and nothing to be concerned with.
    Overall, I would say you have the heart of a very nice system there.
    Also, fantastic that Kenwood was kind enough to send the spec sheet on.
    :smashin:
    Steve/bluewizard
