Soundstyle AV rack leg extensions ??
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by *ChrisB*, Apr 27, 2005.
  1. *ChrisB*
    *ChrisB* Member
    Apr 22, 2005
    307
    +9
    I'm just about to (tommorow :thumbsup: ) update my AV amp but the new amp is too large for my 5 tier Soundstyle rack :(
    I still like my current stand so I don't want to change it, does anyone know a way of extending or spacing the lower tier legs to make room for the new larger amp ?
    Chris
  2. inzaman
    inzaman Moderator
    Dec 16, 2002
    7,681
    +762
    What Soundstyle rack is it as i though that they were all fixed shelf designs as opposed to modular.
  3. *ChrisB*
    *ChrisB* Member
    Apr 22, 2005
    307
    +9
    I dont know the model name ? I bought it in '99
    Here's a piccy (sorry about the quality)
    Chris
  4. inzaman
    inzaman Moderator
    Dec 16, 2002
    7,681
    +762
    Is it a modular unit, i.e can you take the different and actual shelf units or blocks of shelves apart.
  5. *ChrisB*
    *ChrisB* Member
    Apr 22, 2005
    307
    +9
    Yes, the top legs have an allen key in the top of each one (under a cover) & the lower legs have a threaded bolt in the bottom.
    So it's possible to remove or add a tier.
    Chris
  6. inzaman
    inzaman Moderator
    Dec 16, 2002
    7,681
    +762
    If the legs are the same or similar diameter to Apollo stands then you could use some of their adjustment blocks. I do have a Soundstyle stand (which cannot be adjusted) in the dining room, but for my hc i have just purchased an Apollo stand due to this level of flexibility.
  7. *ChrisB*
    *ChrisB* Member
    Apr 22, 2005
    307
    +9
    Thanks for the advice, I'll investigate & report back incase the query comes up again :)
  8. *ChrisB*
    *ChrisB* Member
    Apr 22, 2005
    307
    +9
    Sadly not, so I've just bought an Alphason AD5/47 to match my current Soundstyle :)
    Got a great price from Video Services in Watford (got their details from ebay) & picked it up to save on delivery costs :)
  9. inzaman
    inzaman Moderator
    Dec 16, 2002
    7,681
    +762
    Its a shame they didnt fit, i too have brought an Apollo rack as it is just so flexible, i currently have three shelves but you can extend this but you can also extend the height between each shelf.
