Sony RDR HXD1070 DVD recorder. Aspect ratio question?
Discussion in 'Blu-ray & DVD Recorders' started by Silk6911, Aug 1, 2008.
  1. Silk6911
    Silk6911 Member
    Jul 31, 2008
    10
    When viewing certain channels through my new PVR te locked to 4:3 aspect ratio.( eg Sky Sports News, UK History) but when viewing direct from my TV through its internal freeview tuner all my channels are 16:9 which is fine.
    Any help would be great thanks.
  2. ramjet
    ramjet New Member
    May 21, 2006
    3,760
    +676
    if using a hdmi cable check you are using the correct settings as per the manual
    if its scart make sure widescreen has been chosen for playback etc , and use a 21 pin fully wired scart lead
    • Thanks Thanks x 1
  3. Silk6911
    Silk6911 Member
    Jul 31, 2008
    10
    Thanks ram
    Got it.
    SET UP-HDMI Output-4:3--Set to full- (had it at Normal)
    Changed my output to 1080p as well to match the recorder
    Looking good cheers.
