Sony KDL42W653 vs Panasonic TX-L42E6 vs Samsung UE40F6400
Discussion in 'Which TV Should I Buy?' started by Ducini, Sep 9, 2013.
  1. Ducini
    Ducini Member
    Sep 9, 2013
    Looking at buying a tv set that is essentially for gaming (low input lag) and watching DVDs / Bluerays. I do not watch TV through it except on catch up services through the PS3. I just wondered if owners had any opinions on the following, which all score well on trusted reviews.
    Samsung UE40F6400
    Panasonic TX-L42E6
    Sony KDL-42W653A
    Any other recommendations to throw into the mix??
  2. Manatleisure
    Manatleisure Member
    Aug 14, 2013
    87
    +12
    Hi. For gaming I would avoid the Samsung. The Panasonic is a little better but you may notice the lag. The Sony has one of the lowest input lags
    out there so that is the one I would choose out of them 3 for your requirements.
  3. Curly99
    Curly99 Moderator
    Dec 29, 2006
    8,797
    +2,016
    Thread moved
    Curly
  4. VEGACORTEZ
    VEGACORTEZ Member
    Aug 6, 2006
    438
    43
    +183
    Sony is a top choice at 6ms input lag, but samsung F5000 at 46" for the same money is another option at 16ms lag, i did not mention it's 42" model as it uses a different panel. The panny you mentioned at 34ms is a bit high and the sony can match or exeed it in image quality terms. The only other samsung i have heard of with reasonable lag is the 40" F6800, reviewed here on avforums.
