Sony Bravia W65 VESA adapter.
Discussion in 'TV & Projector Brackets & Mounts' started by JButts, Sep 28, 2013.
  1. JButts
    JButts Member
    Sep 28, 2013
    Hey all, I've just bought a 42" Sony Bravia W65.The little white brackets it come with are no use to me as I want to mount it on an angle and not flush to the wall. I've contacted Sony and they suggested a VESA adapter (part number B448584401) to enable me to fix the panel the way I want. Now, I've trawled the www and several brackets suppliers and nobody appears to stock this product. Can anybody please help, it's driving me crackers!!!
    Ta.
    John. :)
  2. Wise Bat
    Wise Bat Member
    Jan 4, 2008
    211
    +9
    I also cannot find this answer out. Want to know if can before purchasing the tv. As it will be going on a sided wall to the bed and need to angle it around when in use.
  3. Callum Sellars
    Callum Sellars Member
    Mar 25, 2014
    56
    11
    +4
  4. Callum Sellars
    Mar 25, 2014
    56
    11
    +4
  5. glospete
    glospete Member
    Jan 2, 2009
    19
