Sony Bravia internet connection problems
Discussion in 'LCD & LED LCD TVs' started by citylightsabove, Oct 12, 2011.
  1. citylightsabove
    citylightsabove Member
    Oct 12, 2011
    A lot of people seem to have connection problems with the Bravia internet TVs. Having dealt continually with connectivity problems for about six months, I finally looked at the internet settings more closely and figured out the obvious problem. For whatever reason, the auto configuration on the Bravia doesn't work properly because frequently the Bravia loses the correct address for the domain name server (DNS). When this happens, the TV is connected to the local network but has no internet connectivity. The DNS address is showing up as the same address for the gateway, which isn't correct. This happens intermittently.
    To resolve the issue, reserve an IP address on your router high enough that it won't conflict with other devices (i.e. 192.0.1.95) then go back to the TV and do a manual network configuration. Manually enter in the reserved IP address and then enter the correct primary and secondary DNS servers to match whatever your internet provider uses for a DNS address. I've had no problems since doing this manual configuration.
